Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
Portable external hard drive
I purchase a usb 2.0 portable external hard drive. When I plug into my PC (window xp) it does not recognize nor display a new drive. The external hard drive does work in two other pc.
  • jepsjackson Jul 23, 2008
    all the ports are working with other device plug-in and the external hard drive works on other pc.
    The feed back provided on portable external hard drive was correct.
  • 2,794 Answers
If it does see it try this:
Go to the control panel
Go to Administrative Tools.
Go to Computer Management
Under the storage Icon on the left side of the display select Disk Management
See if there is a partition that looks like your external hard drive that has been accounted for, doen't have a drive letter assigned to it, and reformat it if there is one for NTFS.
Posted on Jul 23, 2008
    Genius:
  • 1,226 Answers
Maybe you have to update the usb drivers install in your PC. also use ports at the back of the pc this will always be detected if there is no error of the usb ports. since; that portable usb is working properly in the other pc.
please tell me what happen after you have done.
melnavz
  • Emelio Navaja
    Emelio Navaja Jul 23, 2008
    Hello again,
    insert the CD utility in the board and then, reinstall the USB drivers,
    Goto device manager and then right click the USB and then update and browse the CD where the driver store.
    melnavz
  • 2,427 Answers
Hmm
ok
1.) un plug the harddrive in
2.) click start , right click my computer then click properties
3.) click hard ware, then device manager
4.) right click any where and choose scan for hardware changes
5.) under disc drives / external media see if anything is highlited yellow or disabled
6.) plug the drive in now
7.) right click again and select scan for hardware changes
  • Rishi Roshan Ali Jul 23, 2008
    Did you try my suggestion ?
    Novelist:
  • 143 Answers
Since you said that it worked with other two computers, we can say that there's no problem with the hard drive. try to use another usb port on the computer that is not recognizing it. if you are also using a usb hub, directly connect the hard drive to the usb port and check if it''' be detected. check if the usb port of the computer is enabled or installed properly. you can check if it's installed properly under "device manager". check the bios if the usb port is enabled.
hope this'll help you.
ciao!
    Genius:
  • 2,028 Answers
Depending on hoe old the machine is, the usb ports may not have the power to support some of the newer externals. I recently purchased a WD 250g external and the ports on one of my older machines doesn't have the power to support it. Check the owners manual or with the manufacturer to see what the input rating is and cross reference this to the output of the ports on your machine.
  • 1,879 Answers
Greetings,
It's the USB port on that computer.
Try all USB ports and make sure you got it connected DIRECTLY.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
Hope this helps
Nov 07, 2012 | Computers & Internet
How can I install the driver for My Passport WD External HDD 500GB online?
It is a "plug-and-play" device, and Windows XP/Vista/7 are "plug-and-play-aware" systems.
So, just connect it, and Windows should recognize it.
Are you getting any error-messages?
What is happening?
What is not happening?
Nov 11, 2010 | Western Digital My Passport Essential SE...
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
WD Elements external hard drive not recognized/can't be found
ur vista version has a problem with usb portable devices so either u have to upgrade ur vista to the latest on or install windows 7 or down grade ur laptop and install windows xp
Jul 27, 2009 | Computers & Internet
SeagateFree Agent Go 120 G.B external portable hard drive When I connect that in to my lap top (HP Pavilion) windows can recognize the hard drive and once I connect that same one in to my desktop windows...
you will need to install the drivers for your drive.
xp doesn;t recognize 2.0 usb unless you install drivers and have a usb 2.0 port
but install the drivers and you should get it to recognize
you can go to control panel, system and device manager.
look for a usb device that is not working and right click install drivers or update drivers.
See if it comes up.
Once it does you will see it in the device manager under disk drives
Jun 05, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
USB External hard drive 160 GB not recognized by desktop Windows XP OS
Very possible your problem is that this drive is not externally powered and your desktop does not put out enough power to drive it.  I'm guessing your desktop is older.  Especially if your desktop is USB 1.0 this problem would occur.  Your best bet in this case is to either mount a newer USB expansion card into your desktop, or get another externally powered harddrive and transfer data over to it from this one with your laptop.
Nov 01, 2008 | Verbatim SmartDisk Firelite Portable USB...
External Drive Recognized
is it possible for you to plug it into another PC?
to see if the problme is the HD or a drivers issue in your PC.
Jan 20, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Computers & Internet Logo
233 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
