Question about Vacuums
Hello, I have a wonderful Dirt Devil vac for my carpets, model 140000, love how it works to get doggy hair off my carpet! But, I have a cute cannister model for my laminate floors and it uses the Q bags, but they are no where insight to get or order. Can you help me with this dilema?? Anna
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=821035
Generic problem for all Vacuums
Posted by dutchtreat on Jul 23, 2008
Hello, I have a wonderful Dirt Devil vac for my carpets, model 140000; love how it works to get doggy hair off my carpet! But, I have a cute canister model for my laminate floors and it uses the Q bags, but they are no where insight to get or order. Can you help me with this dilemma?? Anna
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You should be able to get the bags @ your local vacuum cleaner dealer in your area but if not contact the Royal factory cust serv and they will get you in touch with the parts dept and they can mail or ship out the Q bags from the factory. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 23, 2008
My dirty devil vacuum cleaner is not picking even the tinniest dirt off the carpet
Has the hose at the clearer head gotten clogged with carpet fibers, that is the common reason for this.
Sep 21, 2016 | Dirt Devil Vacuums
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
How to adjust height on bagless dirt devil featherlite
Hello! The M085435 has an automatic height adjustment. The vacuum will adjust to the carpet height without you having to do anything. Hope this helps!
Apr 25, 2014 | Dirt Devil FAN, FEATHERLITE MODEL...
Can you clean carpet with dirt devil floor keeper
Refer to http://www.dirtdevil.com/products/details.aspx?id=MCE5500 for the manual.
From the looks of the manual it's just for flat floor surfaces (vinyl, lino, tiles, etc).
May 25, 2010 | Dirt Devil CE5500 Floor Keeper Upright...
The belt is intact but the aggitator doesn't spin anymore. Had a horrible rubber smell, went to change belt. Not the problem. Anyone know what could be wrong? Dirt Devil bagless w/dirt indicator
Even though your belt is intact it still could be worn. if you tilt the vac up (roller off the floor and the roller spins, replace the belt. on most vacuums the life of the belt for optimum performance should be 9- 12 months. If your vac has a carpet / bare floor selection, check to make sure it is in carpet mode.
Oct 10, 2009 | Vacuums
Dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Apr 28, 2009 | Vacuums
Lost instructions on how to use my dirt devil platinum force carpet cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=852232
Posted by Brad63ford on July 29, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get the owners manual is from Royal itself and to contact the Royal factory @ the phone # listed below and to give them the brand name and model # in order to get the correct owner’s manual for your particular vacuum cleaner. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jul 29, 2008 | Vacuums
I have an older model Dirt Devil carpet shamppooer, Model # CE7100WC. The sprayer does not work.
ne of the hoses may have a hole in it you may purchase one at a vac store ner you
Jun 22, 2008 | Dirt Devil Vacuums
Vacuums Logo
109 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
