My toshiba laptop adapter is beeping when i plug it into the wall, and it isn't charging my laptop.
  • 39 Answers
It is more than likely the dc jack on the back of your laptop. You can test the power adapter itself simply with a voltmeter.
Posted on Jul 23, 2008
Lenovo 3000 g530 4151 battery is not charging,give the solution
When you connect and disconnect the AC adapter, do you hear a beep? If you do not hear a beep, check the AC adapter for the following.
1. Check that you have power at the plug in the wall. Don't laugh, this happens.
2. Check the cable that plugs in the wall is fully plugged in the adapter. It needs to be fully seated.
3. Check the cable that plugs into the computer. Make sure is not damaged from running over with chairs, etc. or maybe someone tripped on the cord and damaged it.
4. Measure the voltage at the plug with it disconnected from the computer. It should be the same voltage as marked on the sticker. If you are not getting the correct voltage change the adapter.
5. If you are getting the correct voltage, you may have a bad battery, or a bad motherboard. Replace in that order.
Feb 04, 2014 | Lenovo 3000 G530 4151X3U Laptop Charger...
My toshiba satellite series a135-s4656 laptop stopped charging for over two weeks now. Though the adapter (power pack) is functional. Please what do i do (cos the system has been down since)?
How do you know the ac adapter is working? Just because the light on the ac adapter is on doesn't mean it's working. Does it work with the ac adapter plugged in? Just not charging the battery. If in the first case just buy a new ac adapter and see if it works, most are affordable some not so much. If the battery isn't charging then you will have to shop for a new battery. If both of those are good then you have either a bad ac plug on your laptop, or motherboard issues. Hope this helps, if you have more questions just reply and I will try to help.
Aug 01, 2011 | Toshiba Computers & Internet
Toshiba battery charger pa3468u-1aca for satellite L305-s5944 is beeping and the unit is not charging, what is wrong?
Probably a failed AC adapter. Please try to charge the laptop with a good, working AC adapter & see if the problem disappears.
Jun 12, 2011 | Toshiba LAPTOP AC Adapter Power Charger...
Toshiba Laptop not charging
So confusing...Laptop AC Adapter nowadays has AUTOMATIC VOLTAGE, meaning it doesn't matter if it is 110v or 220v. Maybe you've got a FAULTY BATTERY. Remove the battery and plug in your AC Adapter to outlet and to your laptop and try to power-on.
machinetosh of (tipidpc.com) site
look for kuya boy laptop
Global PC Laptop Professional Services
09126888500
Apr 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
How do I switch from battery to power on my Toshiba Tecra 8000?
Mama,
You do not have to switch from the battery to power as long as the powwr adapter is plugged intp the wall socket and the laptop. When the battery goes low it starts charging while running the laptop and when not charging it runs the laptop alone. I hope that relieves you of your worries?
Nov 05, 2009 | Toshiba Tecra 8000 Notebook
The AC Adapter makes a beeping noise and doesn't charge the batt.
I would verify that the battery will take a charge. If the battery is bad, the charger will tell you that it is not charged. It will not tell you why, just that it is not charged. If not plugged into the computor,again, battery is not charged. Hence, the beep.
Good Luck and hope this helps.
Mar 15, 2009 | Toshiba Portege R100 Notebook
Toshiba satellite m55-s135 won't power on even when plugged in
When the AC adapter is plugged to the wall, if it has an LED make sure it is on, remove the battery and connect the adapter to the laptop, does it power up?
Install the battery after charging, see if your laptop powers up.
If the laptop does not power up, the motherboard needs replacing.
I hope this helps to resolve your issue.
Good Luck.
Mar 15, 2009 | Toshiba Satellite M55-S135 Notebook
Want turn on after it went into hibernation
your toshiba laptop adapter may go wrong, testing by insert it into an other toshiba laptop, if the toshiba laptop battery is not charged,the adapter is the issue, or if you have a multimeter, you can connect the two electroprobe with the input and output port of the adapter,if the pointer does not move, unfortunately,u should change a new adapter
May 18, 2008 | Toshiba Satellite M45-S169 Notebook
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Nov 11, 2007 | Acer Aspire 3680 Laptop
Beeping power adapter
The problem is most likely (85% sure) with the DC Jack itself, that is one of the rarer issues with it. Since it is a 2-state switch, the likelihood of both circuits closing is my guess. And also the cheapest repair. I have been completely through the A75 without a schematic, and have to remember it's quirks in design.
May 15, 2007 | Toshiba Satellite A75-S226 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
