Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi TV Big Irish, I have replaced the bulb and it fits in nicely. Toghten the 3 screws no problem. Turn the power on and I get a blinking yellow light. TV will not power up. The new bulb is clear. Any suggestions?
  • 927 Answers
Good Day, Ritz1234;
Okay, you made sure lamp was seated properly. GOOD!!Now the hard part but the "fix'. On the TV's power supply you will need to change some cap's. But to verify this remove the panel in front, just to right of the lamp panel. Now look closely... reset unit, look, and turn power on, into second panel's opening... if you see the lamp come on for 5 to 10 seconds. Then lamp goes out, then power supply caps need to be replaced.
The power board is on the left hand side of the TV (from the back), power board is in the very back of that left hand ***'y. To repair the supply you will need 4- 1,000ufd 35v, 2- 3300 ufd 35v and 2- 2200ufd 35v caps on that board. They are the only ones on the board, with replacement in hand it will easy to identify parts to replace.
Good luck, if any concerns let me know, good luck, big IRISH.
Posted on Jul 23, 2008
Timer light blinks all the time and TV will not turn on WD-52327
Dear jr37988,
With the blinking red lamp LED (lamp error). Suspect bad lamp part # 915P020010. It very easy to replace your self. Directions will come with Lamp and it is also in your owners manual.
Thank for choosing FIXYA, big IRISH.
Dec 25, 2009 | Mitsubishi Televison & Video
Mitsubishi DLP WD62725 TV after powering down the timer light say blinking till unplug it then reset it to turn back on can any one help me
Good Day,
More than likey you have bad caps on DM Board.
It willcost about $450 to repair or you can do it yourself,.
On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V,
The DM PCB is on the left hand side of the TV when you take off the back cover.
Good Luck, BIG IRISH,.
Dec 15, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have WD 62525 timer blinks very rapidl but wont turn on or off
HOwdy;
Try unplugging TV from a/c for 2- 3 minutes. Plug back in, turn TV on. If red light turns on (Lamp may light and go out) suspect bad lamp part # 915P020010.
Good Luck, Big Irish.
Nov 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv screen tv
Good Day;
Shutdown at Power Causes: Cause #1 This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Aug 31, 2008 | Mitsubishi WS-55807 TV
Mitsubishi Wd-52525 HDTV Stutis light constant red
Good Day, barryspiegle.
You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
HERE IS THE SOLUTION FOR THAT PROBLEM AND THE ONES YOU WILL HAVE IN FUTURE:
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 50 V).
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Aug 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Ya...Ok
Good Day, egear00;
Did you try the DMD board? Other wise I'm still looking for solution.
big IRISH.
Aug 21, 2008 | Hitachi 60V500 60" Rear Projection...
Mitsubishi Proj TV WD-52825 will not turn on. Continuous blinking green light...reset and unplug no help...HELP!
Good Day, Markes;
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 16 V).
Aug 05, 2008 | Televison & Video
Dm board (power supply) for mitsubishi rear projection tv (ws-55807)
Good day,
mohiuddin;
If the indicator stays on then you may have an DM PCB problem and to correct this do the the folowing:
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Jul 22, 2008 | Mitsubishi WS-55807 TV
Mits wd52525 bulb replacement
Good Day Cawhite;
You replaced lamp and still get flashing light.
1. TV's 'ballst may be bad.
2. If lamp comes on for 2-3 seconds, the problem will most likely be the caps in the power supply. (to see lamp turn on you have to take off back or front (inner panel).
Hope this was helpful.
Good luck, Big Irish.
Jun 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-65511 Turning off
Good Day;
Your chassis V21, 2002 model TV has a problem, but to determine what, try this; press the 'input' and 'menu' buttons on the TV"s front panel for at least 10 seconds. Count the blinks (after releasing); eg blink, blink pause 6 blinks = code 26. The code will repeat 3 x's. The most common problem is the convergence IC's are bad or fluid on the boards.
Good Luck, Day let me know, Big Irish.
Jun 18, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
