Question about Jenn-Air JSD2789GEB Side by Side Refrigerator
Jenn-Air JCD2389GEB - Water dispenser
My water dispenser spills water all over the glass, not in a stream like it used to do. The ice froze up in it and I'm afraid when my sister tried to dislodge the ice from the dispenser, the round white stopper got mis aligned.
Any suggestions? I don't know if it is supposed to sit at a straight 90 degree angle from the door or if it is supposed to sit at an angle.
Thanks!
Jo
Our water line looks to be abut vertical...
Posted on Aug 12, 2008
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-air side-by-side water dispenser leak
Check the fill tube to your icemaker and see if it has ice in it or in the fill cup to the icemaker. Most of the time when this problem happens it is the icemaker spraying the water. It could also be a bad module on the icemaker which can get stuck in the fill position and spray water all over the freezer.
Sep 14, 2009 | Refrigerators
My jenn air freezer is not making cubes. the
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 13, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
JCD2389GES water dispenser over-runs and also starts on own
Low water pressure can be very problematic when it comes to icemaker/water dispenser water inlet valves. If there is low water pressure to the valve, the valve may not seat correctly causing icemaker fill tubes to freeze, icemakers to over/under fill or water dispensers to leak or not shut off fast enough. Check the water pressure to the valve like this:
Turn off the water supply to the refrigerator and remove the water supply line from the water inlet valve behind the refrigerator.
Put the end of the water line in a bucket and turn the water supply on. There should be a good stream of water jetting from the tube. If there is not, the water supply shut off valve is probably plugged and needs to be replaced or there could be an in-line water filter that needs to be replaced. Only use a drill style (non-self piercing) saddle valve http://www.repairclinic.com/SSPartDetail.aspx?s=t-584723-%3d%3di584723&PartID=584723 for the water supply.
If there is a good stream, the water inlet valve that the water line connects to at the back of the refrigerator should be replaced.
*Note: Reverse Osmosis (R/O) systems should never be used to supply water to icemakers.
TheRepairGuru --- www.repairclinic.com
Jan 27, 2009 | Jenn-Air JCD2389G Side by Side...
I have a jsd2789ges jenn air water dispenser not working at all
hi there,
sounds like you have an icemaker problem. i would recommend replacing it.
Oct 02, 2008 | Jenn-Air JSD2789GES Side by Side...
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Jenn-Air JSD2789GEB Side by Side Refrigerator Logo
197 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
