Question about Honeywell Heating & Cooling
I have a vision pro 8000 thermostat how do i change it over to auto change over?
  • 80 Answers
SOURCE:
What does it mean when it comes on AUX heat?
The system type has been incorrectly set during the installer setup. The t/stat thinks there is auxiliary heat equipment that is controlled by a signal on the Aux-E terminal which you obviously don't have. My recommendation would be to go to the Honeywell website and download a copy of the installation guide for the FocusPro 8000 and go through the installer setup again but select the appropriate system type under setup function 1.
Feb 13, 2016 | Honeywell Vision Pro 8000 Touchscreen...
Honeywell visionpro
Um...., you changed the controller and it worked, then put the old one back and it doesn't work >> replace controller!
Oct 16, 2013 | Honeywell Electronic Programmable...
How to unlock screen
Change battery located on back of thermostat??
Go to google
Search for your model number 1234XX .pdf
Add .pdf in search parameter.
Honeywell posts most their thermostat manuals.
Open pdf file, and then Use Ctrl+F for search feature
Word-Search manual
To find model number on thermostat, remove from wall.
Model number appears on back.
Don't forget to replace battery while you have back exposed.
Dead battery can also cause lockout and malfunction
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 18, 2013 | Honeywell TB8220U1003 Commercial Vision...
Need Manual for honeywell vision pro 8000
Go to Honneywell website. Should be there. May take some time to locate it.
Nov 08, 2011 | Honeywell Programmable Thermostat Heater
On our thermostat it is reading E3 why is this and how can we fix it
is it a newer model like a Vision Pro 8000? with those t-stats if there is a short in the thermostat wire it will short out the thermostat and read an error problem such as the e 3
Sep 05, 2010 | Honeywell Programmable Thermostat Heater
Honeywell TH8320u Vision Pro 8000 Digital keeps calling for heat
If the thermostat is not over shooting the temperature than don't worry about it.
These thermostats are very sensitive and will turn the heat back on even before the degrees drop on the display. Often they will shut down before the display changes also. You can change the sensitivity of the thermpstat if you read the directions and change the cycles per hour to a less number. There is an installers program in there that you need to push a combiunation of buttons to get too. The instructions tell you how to do that also.
Hopefully you did not throw away the instruction manual for your t-stat.. :-)
Heatman101
Dec 28, 2009 | Honeywell Programmable Thermostat Heater
Upstairs honeywell thermostat went out on 3/7 [no display]
FIRE THIS GUY!!!!
You have two systems.
These two systems should be wired totally independent of one another. I have the Pro series t/stat in my house. I love it.... I am a retired contractor I get stuff at cost. I paid about $130 for that t/stat. I understand he is in business to make money. But he should be fair enough that in the future you would want to call him back, Or even give him a nice referral. Alol this guy wants is your money. If the first guy admitted thatbhe did not have the expertice. He shouldn't be paid the experts price.
Call your city or county building inspectors office. Tell them that you would like a list of 4 or 5 reputable heating contractors in your area.
$275 should be fair for the nice t/stat and a fused transformer. Although a cheap t/stat would be fine.
Plus 75 bucks to pull upthe driveway. 60 -90 bucks labor to staighten things out. You should not have to pay for the romantic weekend away for the contractor and his wife.
GOOD LUCK!
Mar 08, 2009 | Honeywell Programmable Thermostat Heater
Locked screen on a vision pro 8000
select system, hold down the two boxes immediatly to the left and right of the center box for 3-5 seconds
Nov 01, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
503 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
