Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
Antenna Error Hi, I have the MyFi unit in my car and the last few months have been problematic with my antenna. I will have to jiggle the antenna wire to get it to work off and on all day. Today, it just stopped working. The message on the unit reads antenna and I can hear nothing. If I pop the unit out of the cradle, it will get bars, but put it back in, nothing. This is my second antenna. Any clue?
  • 2 more comments
  • Neilie Aug 27, 2008
    Antenna alert. No station will broadcast
  • mr2man85 Sep 10, 2008
    My Delphi MyFi says "antenna" all the time when it is docked in the car or home. Once I take it out of the cradle it starts receiving and working normally. Any suggestions would be appreciated.
  • Anonymous Sep 26, 2008
    ya dude, same **** for my car. WTF
  • JSHarper1 May 11, 2010
    You may get reception out of the cradle because of local ground based repeaters - I can get signal too out the cradle, but it is not strong.
    Sounds like a bad connection between the cradle and the antenna plug. Hard to test, since you cannot plug the antenna directly into the receiver.
    Do you have a home cradle, and if so does it get signal in that cradle?
    If no home cradle, take a close look at the plug for the antenna - there are little metal pieces that can be bent to make a tighter connection.
    Otherwise, could be a broken wire between the antenna and plug. Did you install the wire so the trunk closes on it? If no obvious places of wear, it will be hard to find the break. But if you do find the break, there is a nice description on XM411.com of how to repair the wire.
    Problem Solver:
  • 14 Answers
Ok i had the same problem with mine it was the power supply but i had mine in the house with the home kit hope this helps
Posted on Jul 23, 2008
No reception
your antenna connection inside the unit is broken on the circuit board,i had one of these and repaired it numerous times by taking the unit apart and resoldering the connection at the board,also their antennas don't last long as far as the antenna plug end is concerned
Apr 30, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My 1993 LS400 (106,000 miles) battery keeps
could be bad igntion switch not turning off all the way keeping power on
Mar 07, 2010 | 2001 Saturn SL
Antenna problem
yes, most likely. What about putting the MyFi in the 'base' with a regular antenna?
Feb 22, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
How do I take apart the MyFi?
take off battery cover, remove battery, remove 'cardboard' and any screws you can see under the cardboard, Then carefully pry apart. There is one small cable that goes from the antenna jack on the side to the top, and another small cable for the built-in antenna at the very top. Both are VERY VERY fragile.
Jan 16, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
When I plug my headset antenna into my myfi I only get partial reception. I have to keep moving the plug around to get reception
Not the plug but YOU have to move around to hit the satellite with the antenna. Unless you're outside in a field, the head antenna is very picky.
Jan 01, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Xm2go direct entry tuning problem
You have it set on a preset mode now. On the unit or the remote control press the "pre/dir" button a few times until you see the word "DIRECT" at the top left of the screen next to the antenna strength. From "direct" you can then key in the channel numbers directly to go to them.
Nov 15, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Xm radio
Try with a different XM Antenna from a friend or shop if possible to verify whether it's the antenna or the unit itself.
Visually inspect antenna cable and connection at the antenna and the unit and make sure the antenna cable hasn't been damaged.
I would do this before considering other options
Good Luck!
Sep 17, 2008 | Yamaha HTR-5940 Receiver
Delphi xm2go internal antenna
Don't use the wearable antenna - reputed to not work well - was not a good design idea - I don't think any of the other receivers have this feature if that tells you anything. Record music you like on the myXM feature, and play that when you would otherwise want to receive on the antenna. If you are listening to live news, etc, there may be no good solution. (I have read there is an antenna headset, but don't know much about it, but some reports that it works.)
Jul 23, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Surius Can not find antenna
A couple of possibilities all based on the assumption that the unit actually turns on.
1. Broken or disconnected antenna wire.
2. Broken antenna (The antenna is powered from the unit)
3. Broken unit.
Dec 27, 2007 | Sirius Satellite Radio Receiver
Reception
While in the truck, make sure the antenna is on the outside of the truck. It has magnet so it is easy to stick to the roof. Do not know what to say about the home antenna, mine is not working right now.
Dec 14, 2006 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
132 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
