Question about Sharp FO 5700 Plain Paper Laser Fax
Error message How do I solve the issue "RX doucement tray off"
The Tray is seated properly, but i am still coming up with the same error message RX document tray off..
Posted on Apr 27, 2009
    Scholar:
  • 75 Answers
When you look at the front of the fax. above the paper cassette there is a gray,blue cover where the paper comes out when receiving or coping , that cover needs to be seated properly there is a mag switch that will shout down machine till it is in place.
Never have I seen this sensore go oit just the cover is out of position,
hope all will be OK
Posted on Feb 03, 2009
How do I make a copy
put your orginal doucement on plate glass and select how many you want find print on your equipment depending on what kind you have are you might find a start button press it and you should see you are coping your doucement good luck
Jul 08, 2014 | Canon Pixma MX452
Not printing black on right side of doucements
Run the PQ Troubleshooting diagnostic
Check out the BLACK page.
You can also run the Disable Cartridge Check diag.
This test will enable you to pull all the cartridges out, and put the black into any other slot. Then print the Configuration Page and see if the problem follows the black cartridge. If it prints good this way. Put the Cyan into the top slot(black), print the config page. If it prints bad, it's not the cartridge it's the printer.
I think that replacing the Black Cartridge should solve your problem.
Jan 05, 2011 | HP LaserJet 3600dn Printer
Fax error message = TX cancelled:RX fax info mismatch???? Cannot send fax - How do I fix this error - Not all faxes return this message
Two Issues:
1. The Transmission Speed of the MX860 may be too fast.
Solution: on FAX Menu go to Settings>Device Settings>FAX Settings>Transmission Settings >"TX start speed" and change to 14400 or lower (14400 worked for me).
2. The recipient FAX machine may be receiving by a different number than the one you dial. This may occur if you dial a free-calling no.
Solution: Go to Transmission Settings as above>"Check RX fax info" and turn it to OFF. This disables the mismatch issue.
Hope this helps. aknz
Jul 31, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
When I try to print with HP Photosmart, I get
Hey Cathy,
One of my clients had this problem as well. It is due to your sensors not working correctly. In the tray there are two clips that hold the paper tight, keep trying to adjust those clips and this should solve your issue. However, if this does not solve your issue - you most likely have a hardware issue and parts will need to be replaced.
Jul 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
How do I change tray settings from tray 1 to tray 2?
Browse through the menu's of the printer
Paper Handling Menu, Set
Tray 1: Any size / Any Type.
Tray 2: A4 Size / Plain Type.
This should solve the issue
Regards,
Nikhil
Jul 10, 2009 | HP LaserJet 2420 Printer
A friend gave me this fax machiene. On the screen it sais "out of paper" when there is clearly a lot of paper in the bottom tray. However it is missing the top paper tray but has the lower tray. Could
Make sure you have a receiving tray. You can live without your sending tray. If you have the receiving tray and it says TRAY OFF thats because its not seated properly onto the frame. Make sure the tray engages the black sensor next to the speaker, also make sure you have paper in both trays to get rid of the OUT OF PAPER error. If the OUT OF PAPER error continues then you have a broken sensor in the upper tray.
May 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Muratec mfx-2000 error problems
please check the switch of mentioned cover may be it is abnormal or open and close the front cover or check may be there is one reset switch in your machine
Sep 26, 2007 | Muratec Copier
Sharp FO 5700 Plain Paper Laser Fax Logo
176 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
