Question about Sega Genesis 2 Console
White lines on the TV
When i turn on my Sega it has white lines running through the tv, and it prevents me from playing, ive cleaned the cartridges, and the sound of the game doesnt come up, and i can barely play the game, this is really starting to annoy me, can anyone help.
  • 52 Answers
Sounds like the video processor has died
It will be cheaper just to buy a relacment console
if you can't find one locally then try ebay
http://shop.ebay.co.uk/items/?_nkw=megadrive+console+only&_fromfsb=&_trksid=m270
also you may wisdh to consider a RGB lead for better quallity video picture
http://www.retro-cache.com/
Posted on Jul 28, 2008
How to connect sega master system 2 to lcd plasma tv
If your TV comes with a composite video input then this may not be an issue. You need the RCA AV cable. Sega outputs only mono audio so put Yellow in TV video In and White in TV audio In (white connector).
http://www.gametrog.com/GAMETROG/HOW_to_connect_Hook_Up_SEGA_Master_System_Instructions.html
If you still have the RF box for the Sega then you should be able to put RF from Sega and TV antenna to the RF box and connect RF box to TV antenna in.
If TV is only HDMI input then you need a converter like this
Composite Video to HDMI Converter
Sep 04, 2014 | Video Game Consoles & Games
Sega mega drive with av cable
if your screen is black and you unplug the cable from the megadrive , does the screen go blue ? if so the machine is sending out an a/v signal to the tv and your problem lies with the game cartridge contacts being dirty or the contacts in the slot on the console being dirty , try cleaning the contact strip with some electrical contact cleaner on a cotton bud or small paint brush , hope this helps ,its saved loads of my games
Aug 10, 2012 | Sega Megadrive Black Console
How can I hook my sega genesis console to my Direct tv box?
Don't plug your Genesis into your satellite box. Plug your Sega into the back of your TV set. Get a Sega Genesis composite video cable. Run that cable from the mini-DIN connector on the back of your Sega to the RCA (yellow, red white) connectors on the back of your TV set. If you don't have any spare RCA connectors on your TV set, try a composite video switch.
Aug 20, 2011 | Sega Genesis Console
When I play a game on sega the tv screen is black and white. What can I do?
Well its because that the rf switch or the av cable with what you are using is causing this type of a problem then Not the console. Or it might be the tv too then.
Jun 26, 2011 | Sega Genesis 2 Console
My genesis model 1 turns on but the screen stays fuzzy i tryed the rf out to the back of the tv it still is fuzzy. T try it with the yellow and white wire cords that go in front of the tv still fuzzy...
The game cartridge terminals and the console receiver require disassembly and cleaning as per this service.
It is easy enough to do yourself with the proper tools. If you would like, we can perform this service for you.
Thank you and best regards.
Apr 12, 2010 | Sega Genesis Console
Plugged in Sega and tv screen just showed wide white lines scrolling up. Not sure if it is the cord or the machine.
The TV isnt compatible with the machine... get a new up to date console and stop living in the '80s
Apr 08, 2010 | Sega Genesis Console
Genisis not playing correctly/audio cutting
you av cable is going bad or you have a bad connection,,,
ive been thru 3 of these over the years and the black and white is the first warning sign
the sound is the second,
you can find em on ebay really cheap
Nov 03, 2009 | Sega Genesis Console
Sega Genesis not showing a picture
As I had just a similar problem with my MegaDrive/Genesis maybe this helps: Try an older TV set. I am not joking. It might very well be the case that newer TV sets/high-end TV systems can't handle the signals of the older video game systems. I have a 100 hz TV set and whereas there are no problems with a SNES, with the MegaDrive I just had a black and white screen with bars running through it. On a 60 Hz TV set this problem does not occur. Keep in mind that there were no 100 hz/HDTV sets around when these video game systems were in general use.
Jun 18, 2008 | Sega Genesis Console
Sega Genesis 2 Console Logo
134 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
