Question about Maytag MZD2766GES Side by Side Refrigerator
MZD 2766GE refrigerator: freezer side is cold but refrigerator side gradually warms after a week and then freezer side warms.
The refrigerator side maintains a cool temperature for about 2 weeks before there is no cooling. At the same time, the freezer side starts off cold but gradually warms. After about a month, the freezer side is warm. On the first occurrence, there was ice on the bottom back wall of the freezer. After defrosting, the unit worked as previously described. I have defrosted and restarted the unit 3 times with the same results.
I have noticed the air movement from the cold air vent at the top left side of the refrigeration section is very weak despite the freezer fan seeming to work properly. The weak air flow persists regardless of having the control temperature arm in the temperature control unit at the top of the refrigeration section being set at the coldest or warm setting. Before the temperature problems are noticed, there is a clunking noise that seem to come from the top area of the unit.
Thanks for your assistance.
Barry
  • Brisbee Jul 29, 2008
    Same problem. Refer side warms the freezer gets colder then eventually gets warmer. A&E repair (never use them) has been out 3 times and unable to fix it permanently. Help.
    Problem Solver:
  • 9 Answers
MZD 2766GESide by Wide Unit problems
Be sure if you get into the refrigerator disconnect the power!
I had the same problem and I knew it was the refrigerator. You have to order the control board that controls the fan assy in the freezer. It has an inherent problem with others I see. But don't attempt to change it yourself. There is tricks to it and if you don't do it right you will break more things. I saw the tech broke some tabs and it is stupid way to design something unless you plan to get more business this method.
The control board sits in front of the water filter in the refrigerator. Inside the Temperature control housing cover.
Additionally, you have to take all the frozen food out and defrost manually the fan area and the subsequent ducts to clear it all out. Otherwise, you will have the same problem again. If it breaks and it will. It causes the ice to build up to point you will not get fan movement or airflow. This flow keeps the Icebox from freezing up and causes the air to flow to the refrigerator side.
They make these things so it is harder for DIY to do it.
But they are really simple! At least most of it.
Contrary to popular belief Ice is a good insulator. Once it builds up, no heat transfer takes place because of the inefficiencies it blocks the airflow and etc.
It is my opinion and I stand by it.
I bought many Maytag items and it suppose to have a great reputation. I have now started to look at other providers.
I find these companies are getting cheaper and instead the quality is going down.
So buyer beware not all have across the board quality it depends on the series, the price and the manufacturer.
Oh well another lesson learned.
Here is another problem when using a ice maker unit do not always use the ice crusher. I found that out. The motor that drives the ice crusher is matted with metal to plastic then metal again in the Ice Holder unit.
Guess what, it jams sometimes and it puts great pressure on the ice maker holder unit.
Where the metal meets the plastic is the weakness. It breaks because of in my opinion weak design
The two plastic nibs meeting with the metal motor drive square "U" connector breaks the plastic and eventually you have to get the plastic replaced. I think if I have to order that little part will end up buying the whole Ice holder assembly.
One direction for crushed ice the other direction it turns for solid ice cubes.
I guess I will use the solid Ice cube method until I figure what to do.
Any parts for it replacing the plastic hookup out there?
Good Luck!
Posted on Jul 27, 2009
    Champion:
  • 210 Answers
Defrost problem. when you defrost make sure all ice is defrosted or it will turn into hard ice and will be difficult to defrost.
Posted on Aug 07, 2008
fan won't start by itself.
Posted on Aug 10, 2008
Why does The freezer side stays cold but the refrigerator side gets warm
Your problem is more than likely a defrost issue. There is ice building up in the freezer coils and when it gets blocked with ice the cold air cant blow into the fresh food section. When you shut it off the ice melts and it gets cold again for a few days. remove the freezer back panel and check the defrost heater and defrost thermostat. if they check OK then check the defrost timer. It is best to replace all three components at the same time. This way you will be starting out with new components rather than one failing then the other.
Jul 16, 2014 | Kenmore Side by Side Refrigerator
Freezer too warm, and i feel heat on the door seals
The door seals warm is from the mullion heater that minimizes moisture from forming in that area, under working conditions. You need to provide more information.... What did you see that made you defrost it 3 weeks ago..
Nov 27, 2013 | Kenmore 53542 / 53544 Side by Side...
My Maytag fridge model # MZD 2766GE has stopping cooling both sides fridge and freezer sides. What could be the problem?
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Apr 04, 2011 | Refrigerators
Freezer in the gararge redfrigerator quits working when outside temps get real cold
hello. this is a common problem. The thermostat for a refrigerator/freezer is in the refrigerator part. Normally the refrigerator is kept at around 40 degrees. The compressor turns on as required to maintain this tempearture. The evaporator coils are concentrated in the freezer side, so that the freezer stays at around 0 degrees while the fridge side is held at 40.
If the ambient temp is around 25 degrees, the refrigerator compartment will get below the setpoint of 40 degrees, and gradually continue down towards 25 degrees. The compressor will not have to run at all to maintain this. In fact, the compressor is designed not to run, once the refrigerator compartment gets below the setpoint, for fear of freezing the contents of the fridge.
The lack of circulating refrigerant due to the non-running compressor means that the freezer compartment will gradually warm up to 25 degrees.
If the unit were just a freezer, it would work fine in the unheated garage. If it were just a refrigerator, it would not run in these conditions, and the contents would eventually freeze, but it is otherwise OK.
Regards, Joe PS kindly rate my answer. Thank you.
Jan 19, 2010 | Refrigerators
G E side by side refrig . freezer cold but
you have a defrost system problem timer or heater or bimetal tst could have a electronic defrost timer
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator hardly cold freezer not freezing
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 29, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Cooling and freezing gradually getting worse
check the coil underneth the unit for debris and alos if the fan is working or not
May 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Freezer is very cold refrigerator is warm
you have a defrost problem. could be your defrost heater or your defrost thermastat or i belive yours is a newer one with the electroic defrost timer
Jul 02, 2007 | Maytag MSD 2655 HES 26 cu. ft....
Maytag side by side model GS24C8C3EV Refrigerator too warm
it is almost certainly a defrost problem. when fault has occured, remove freezer bzck panel and see if there is ice build-up. if so this confirms a defrost problem - possibly that the element is open circuit
Jun 21, 2007 | Maytag MSD2434GE Side by Side Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
567 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
