Question about Maytag Dryers
How do I replace a blower wheel in a maytag performa clothes dryer?
  • 1,028 Answers
Lift top remove front panel
Posted on Jul 23, 2008
I have had to replace the blower wheel on my Maytag Performa Dryer twice in the past 2-3 months. The wheel when removed looks as though it is being ground down. Could there be something else wrong?
Just check that the dryer vent out the back hasn't been pushed into the machine. Sometimes when the dryer is pushed against a wall the vent can be pushed back into the machine somewhat, which will in turn push the blower wheel housing forward and deform it slightly, causing the blower wheel to rub on the housing.
Jul 06, 2011 | Dryers
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
My Maytag Performa won't run at all
I looked up your model. The blower wheel on these 31001317
causes the dryer to over heat. The fuse kit LA-1053 mounts here:e930c75.jpg
Apr 13, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Performa Dryer doesn't heat up properly. Takes 2 to 3 cycles to dry clothers. Recently changed elements. Maybe a little better but not much. Any ideas?
I replace an awful lot of blower wheels on these. The flat portion of the plastic blower melts causing the wheel to be loose on the shaft. I have repair photos HERE
I pop the top and remove the front, then remove the old blower wheel and clean out the dryer, oil the rollers and idler and check the glides for wear. When I gits that baby back together it be sweet.
Feb 26, 2010 | Dryers
My Maytag Performa dryer is taking 2 and sometimes 3 cycles to dry clothes. Suggestions as to why?
Most of the time the dryer blower wheel part number 53-0106 gets loose and and cause this problem. I fixed one just the other day.
Feb 24, 2010 | Maytag Performa PAV2200
Dryer making loud squeaking noise
Check the following:
  1. Idler pulley - It keeps tension on the main drive belt and when it is worn, it can be squeaky and noisy. Replace then.
  2. Glides - Attached to the front bulkhead of the clothes drum for support. When worn, it can be noisy and squeaky.. Replace then.
  3. Rollers or wheels - They support the clothes drum. When they are are worn, you should replace the whole set of rollers at the same time.
  4. Blower wheel - It pulls air over the heat source through the clothes drum past the thermostats, then pushes it out the exhaust duct. It may wear out over time. If it is noisy, it may be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it.
Oct 18, 2009 | Maytag Performa PAV2200
I have a maytag performa dryer model #pdet920ayw and when i turn it on it squeels.
Below are some links, courtesy of, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
The most common cause of a squeal is the drum roller, of which there are 2. It is usually a good idea to replace both rollers, roller shafts and drum belt at the same time, as they have a tendency to wear at the same rate. You must also use the proper lubricant on the roller shafts, (Syl-Glide), or you will have a recurrence of the squeal.
1. Drum Roller Image
If your dryer is noisy, check these:
Idler pulley
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
You can also obtain more appliance information at my website,
Aug 27, 2009 | Maytag Dryers
Maytag Performa PYET344ATW dryer noise problem
unplug the dryer.
Raise the lid.
Remove the front panel.
Inspect the blower wheel on the motor.
If loose on the shaft, replace it.
Inspect the glide supports on the front drom support.
Remove the drum.
Inspect the rear rollers for sticking.
Inspect the belt tension roller for wear.
Mar 12, 2009 | Maytag Dryers
Maytag Performa Electric Dryer Won't Start
check the blower wheel, sounds to me like it is loose on the blower motor, common on these dryers. One sure sign would be a warped filter and a rusted top. The blower aint putting out enough and the dryer is over heating .
/uploadswith image
Mar 08, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
249 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
