In most cases there is a digital timer on the machine or a manual timer. The timer should be located behind the panel behind where the container sits below the funnel. If it is a manual timer you can simpley turn it up in small increments. If it is a digital timer you will need to unplug the machine, find the little dipswitch on the board the will read set on one side and lock on another. Set the switch to set, plug the machine is and hold down the brew button til you hear 3 clicks. After the third release the button and let it fill to about 2/3rds of the way up and turn it off. If it is still not correct you can repeat this by turning it back on and holding down the brew switch but allow it to go either higher or lower of the previous level til correct. Hope this helps.
WWW.MidstateBeverage.com
