Question about Carrier Heating & Cooling
The outside unit refuses to come on resulting in no cooling in the inside
  • 143 Answers
You have an electrical problem. It is either a lack of 220 volts getting to the outside half of the a/c or the 24 volt circuit not activating the contactor (big relay) that carries 220 to the compressor.
Posted on Jul 23, 2008
My breaker trips when the outside unit tries to turn on. The inside furnace runs. I cut the inside unit off and the breaker doesn't trip. I manually turn on the outside unit by depressing the cont
Hello, there is a short to ground somewhere, check all the wiring from the inside un it to the outside unit and make sure nothing is touching metal.
Jun 10, 2012 | Goodman Heating & Cooling
I have a LG Artcool LAN121HNP the unit will only ciculate air (not cool) it is only 2 years old. I have had an HVAC guy look at it, he says the compressor is fine. We have put a new board in the outside...
Make sure none of the thermostat wires from the inside unit to the outside unit have come loose or have be cut by a weed eater or such. These units are a little more complex than your average heat pump.
Aug 24, 2010 | LG Art Cool LA181CNW Split System Air...
I HAD A PAPER JAM, HAVE REMOVED THE OBSTACLE BUT NOW IT WON'T SHRED
monaswan, If the motor refuses to run, unplug from wall outlet. Then let it "cool down" outside for about 1 hour. Then try it again. There is a "temperature sensor" inside unit that "opens-up" and will not let it run until the ambient temperature falls to a safe operating area. Reply after 1 hour and let me know if that was solution!!! 12fixlouie
Aug 20, 2010 | Royal Office Equipment & Supplies
I tring to change thermosat I can not remeber what color go where
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Heating & Cooling
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Trying to figure out thermostat wiring diagham on a split system
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 05, 2010 | Heating & Cooling
Goodman Air (outside unit)
was there any refrigerant loss? "bumping" that results in movng usualy causes a leak.If the system is totally empty, It shouldn't start.. If it did major oh nos! will appear. Does it not start all? and was it running when it got thumped? May have to call a tech out on it. Sorry.
Jul 29, 2009 | Goodman CKL42AR42 Air Conditioner
Outside unit not working
If the heating and cooling is working O.K. and maintaining the proper temperatures it is possible that your outside unit is in its off cycle. If the inside unit is running and the outside unit is not with an elevated temperature inside check the power supply to the outside unit. Most units have a disconnect located near them. Check the disconnect and make sure it is set to the on position. Listen for a hum noise at the outside unit which could indicate that the control power is being supplied to the contactor.
Jun 15, 2008 | Samsung AS18A6RB Air Conditioner
Lg ductless no ac
I may not be of much help but I may be able to guide you into some diagnosos. If there is a communication problem between the inside and outside unit, both on the inside and outside units a colored LED will bling 5 times then pause for 3 seconds. The 33 and 44 codes are confusing to me because I have never seen this. Try resetting the outside unit with no call for heat or cool from the inside unit. After about 20 seconds, restore power to the outside unit. Go in and turn on the remote and make sure you lower the cool setting more than degrees cooler than the room temp. After 3 minutes the outside unit should turn on. If you get an error code of either 1, 2 or 5 blinks document it for the technician. If you continue to get your 33 and 44, you have a bad control board. If all else fails, press and hold the button located on the lower left side of the art unit and hold for about 5 seconds. If it still no longer works, now you will need the help of someone who knows these units.
Sep 08, 2007 | LG Art Cool LA121CNP wall/window Air...
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
Heating & Cooling Logo
66 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
