Question about Sub-Zero 632 / S
Cannot get ice drawer back on the track 500 series
I cannot get the ice recepticle drawer back in the track of my Sub Zero freezer. The back wheels are in the track, but the front wheels are not. I can't figure out how to get them in.
It is a side by side
  • Anonymous Aug 22, 2008
    i can't get the ice tray back in
    Habit-Forming:
  • 41 Answers
Unfortunately, you need defrost freezer - put freezer thermostat on OFF. You possibly got broken ice tray or damaged sliders.Or leak in ice maker area. Till you defrost that compartment - no chance to pull tray out.
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Cannot get ice drawer back on the track  500 serie - 00000114214-subzero648probuiltinrefrigerator-large.jpeg
Posted on Jul 23, 2008
Sub Zero drawer freezer is filling up with ice crystals. Looks like from the ice machine. Help!
When we had ice crystals in the freezer it was because liner in the top of the freezer where the water is to drain to the back of the freezer and out the drain tube was deteriorated. We lived with it for about a year.
Contact sub zero for information.
Ours was 23 yrs old
Jun 23, 2014 | APW Wyott SubZero Refrigerator Freezer...
Sub Zero 700 TC with two freezer drawers on bottom. Ice sheet is forming on the bottom below the drawers and causing the drawer to stick. I have defrosted the freezer with a hair dryer and thought this...
How are the ice cubes? Are they normal size or hollow? I was wondering if some of the water was not making it into the ice maker and causing this issue. Is there any frosting issue not mentioned? Any water droplets on or around the back wall of the unit (inside)? I am a service tech certified and would like to know more about this issue. Have you cleared the drain completely, meaning after you de-iced unit, did you use water to verify the drain was cleared?
I you like to know more, so I can direct you in solving this issue.
Sep 22, 2013 | Sub-Zero 700TC Bottom Freezer Refrigerator
Sub zero freezer drawer frozen shut
Subzero freezer: We had all our drawers stuck, including the ice drawer. We turned off the refrigerator, took all the drawers out and defrosted the rails with a hair dryer. The ice drawer was misaligned, so we reset the allen screws on the left to be the correct width. All better!
Sep 08, 2012 | Refrigerators
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Freezer drawer on sub zero stuck
chances are it is frozen stuck and also needs lubrication. Do this. Unplug it for an hour and try the drawer. If it doesnt open wait another half hour and try it again. When it does open, dry the rails thoroughly with a towel and then a hair blow dryer. Finally spray the rails with a lubricating spray like WD40 or better yet some white lithium lubricating grease, both products readily available at any hardware store, home depot, etc.
Oct 04, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 642 ice maker
When the drawer is opened, trhe "full arm" swings up and out of the way. When the drawer is pushed back closed, the arm should swing back down. If it is unobstructed, the icemaker should make ice.
One thing to try is with the ice tray removed, push the plate (that holds the ice tray) back into the freezer. Lift the full arm up and down. It should easily move and you should be able to hear a slight "click" when moving up/down. If not, you might have a bad switch in the ice maker unit...replacement time.
Mar 25, 2009 | Sub-Zero 642
Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
http://www.SubZeroLosAngeles.com
Nov 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero freezer 600 series - flashing 'vacuum condenser'. I've taken the vents off and cleaned areas, however, the message light does not come off. And the freezer has formed ice on the back walls.
Our is doing the same thing, except we do not have ice forming on the back of the freezer. We were told by a refrigeration repair company that if ice is forming on the back of the freezer then the compressor is bad.
Sep 17, 2008 | Sub-Zero Refrigerators
Sub Zero Frezzer drawer
I had the same problem. I found the piece of plastic in the ice tray and couldn't figure how to put it back. I ordered a new ice flapper from the parts place on the internet and installed it. The ice maker now shuts off. Good Luck.
Rick S.
Oct 26, 2007 | Sub-Zero 650 / O Bottom Freezer...
Ice maker drawer for sub-zero 632
Look at both those tracks on each side. its likely one or both are cracked or broken. Each one has 2 screws holding it in. To put the metal hange back in the tracks, you must get new tracks (if broken/cracked) then hold the2 tracks onto the bucket carriage...then stick thewhole thing in as an assembly, hen put the 4 screws back in. there are 2 more small screws way in the back (one on each side), but they do not have to be removed, only there to guide the racks in properly. these tracks are only about 7 bucks apeice, and shouldn't take long to chamge. Good Luck!
Aug 02, 2007 | Sub-Zero 632 / S
Sub-Zero 632 / S Logo
486 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
