Question about Averatec 3200 Notebook
Power cord The power cord does not fit the connection and I constantly get shut down. I have just enough time to turn off the computer to prevent losing everything. Can I get a new poser cord?
  • 3,051 Answers
You whould be able to get the right powercord from any reputable computer repair center or you can go thru the manufacture of the computer to get it ok best regards mike
Posted on Aug 24, 2008
Why does myGarmin 1350 keep losing external power and shutting down, then restart, sometimes losing current destination info, sometimes not.
Major problem with the Nuvi 13xx series as well as the 11xx, 12xx & 14xx series is a loose/broken USB jack in the back which is preventing power from remaining constant into the unit. This will also prevent the internal battery from being charged. We can repair this issue and reinforce the jack. Please see this link for more information:
Jun 15, 2014 | Garmin nuvi 1350 Car GPS Receiver
Belkin n1 vision is shutting down
Is the Belkin plugged into a power strip or UPS? Try another AC outlet. Has the AC jack,plug in the rear or the Belkin been damaged due to pulling on the AC cord, causing a lose connection? Is your computer shut down at night? No Hibernate, No Sleep? Are their setting for the Belkin to shut down/timeout after a certain idle time? Here's a user manual: http://cache-www.belkin.com/support/dl/f5d8632-4_usermanual.pdf
Feb 14, 2013 | Belkin N1 Vision Router
Remove versa 6060 bios password
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery
5. Remove the real-time clock (RTC) battery
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Aug 13, 2012 | NEC Versa 6060 Notebook
Hello, I have a problem with my eee 100H5 netbook. I was using it connected to the power outlet, when it randomly shut off. It cannot be restarted and is unresponsive to the power cord, meaning that the...
Unplug the computer and take out the battery.
Hold the power button for ten seconds.
Leave the battery out and plug in the power cord.
Press the power button.
If the computer turns on, put the battery and everything should now work.
This has solved every "laptop not turning on problem" for me and my friends.
sublimedjg
Jun 23, 2011 | ASUS Eee PC 1000HE Netbook
I have a emachines amd athlon 64/ 512mb memory / 160gb hadr drive dessk top. when i turn it on the monitor displays no signal and goes off. ihear the prossessor motor running constantly which normally goes...
Please check the cable that connects the monitor to the video card. Reseat the cable, the issue might be a loose connection. You can also try a known good monitor to isolate if it's the video card or monitor that is causing the problem. Something is preventing the monitor from receiving signals from the video card, hence the "no signal" message.
May 19, 2011 | eMachines Desktop / AMD Athlon Processor /...
I have a LF 95T treadmill that won't power on...no lights, nothing. There is good power coming in from the wall...solutions?? Serial #TCT-107894
it could be a simple solution where the power cord connects to the underside of the treadmill, there is a clip with a screw , sometimes this get loose and the cord slips down just enough to lose contact push the cord back up and tighten the screw
if not this check the plastic connector where the cord plugs into the treadmill it may be actually broken good luck
Dec 31, 2010 | Life Fitness 95Ti Treadmill 95 Ti
Tower intermittently loses power
i think you have a problem in you power supply sir try changing it or try separating your monitors source of power.
Dec 10, 2008 | Computers & Internet
you need a new power supply !!!!
Jul 05, 2008 | HP Pavilion 754n PC Desktop
Power Issue
sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Mar 04, 2008 | Toshiba Satellite M65-S9092 Notebook
Nothing on the screen after power on
Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
Jan 05, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
Averatec 3200 Notebook Logo
35 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
