Question about Motorola Mobility MING A1200
Taking apart the faceplate housing
We are trying to replace the flex cable and cannot figure out how to get the hinge apart.
Hello Was hoping to get a video on how to
First, a freezing problem or lock-up during boot-up has nothing to do with the LCD display. If the screens shows a graphic, such as the Garmin logo and without lines or splotches, then the screen is fine. Lock-ups during boot-up are caused by corrupted firmware or maps or a corrupted flash drive. All of which can be resolved without taking the unit apart. The battery has nothing to do with it either. If the unit locks up while connected to the car charger, then the battery is essentially being charged and not powering the unit. I can't see your board but if you pulled the ribbon out of the board, you may have damaged the locking latch that holds the ribbon in place. The locking latch is a thin white or rust-colored strip of plastic on a hinge. That hinge should be up when sliding the flex cable into the connector, then the locking latch is pushed down toward the flex cable until you hear it click. The flex cable should be secured at this point. If you have busted the locking latch off, it is game over for your Nuvi. More info on booting issues can be found here:
http://www.sharc.net/gps_bootup_repair.htm
Sep 25, 2013 | Garmin Nuvi 255 GPS Receiver
How do i install the keypad with flex cable throught the hinge on a v3?
There are small screws on the silver end pieces that hold the 2 pieces together. You have to completely take the phone apart top and bottom take the end piece out of the hinge and very carefully slide the flex cable through. Go to HowardForums and look for a tutorial there.
Aug 05, 2009 | Motorola Mobility RAZR V3
Trying to remove the slider on SGH-A737
To remove the slider mechanism, take out the 4 visible screws first (under the battery cover). Then on the back of the phone at the bottom, remove the 2 little rubber circles with a tiny flat head screwdriver to reveal 2 more screws, take those out. Take out the 2 screws on either side of the flex cable that is coming out just below the battery compartment. Next is the part that took me hours to figure out. L Beneath where the battery sits is a long oval shaped thing (=======) <- looks something like that (sorry I don't have pictures). This is actually a sticker. Peel this up and remove the 2 screws under it (keep the sticker intact becase you will need to replace it later). This will detach the slider from the phone. Make sure to gently disconnect the flex cable from the mainboard first.
From there you can see more screws that will help you take apart the sliding part of the phone to access the lcd screen if you need to replace it (which is what I was doing). It's pretty easy from there to get everything else apart. Make sure when you disconnect the cables from the back of the LCD screen, that you flip up the little release tabs on the connectors first.
Jun 05, 2009 | Samsung SGH-a737 Cellular Phone
How to repair broken hinge of my Verizon LG Vx8350
I was able to take apart a VX8350 I have with a broken screen. I don't see any way to replace just the hinges with replacing the whole top part of the phone including the screen. The ribbon cable from the screen runs through the hinge part into the main assembly of the phone. It appears the cable can't be removed without cutting it.
Jan 11, 2009 | LG VX8350 Cellular Phone
Replacing the facepale
that hole on that model is for a locking screw, the locking screw is installed to minimize theft and for other precautions. If the face plate is having any odd reactions its normally do to the flex cable. The best sign for a dying or dead flex cable is at the joint. The joint can be viewed at the point when you remove the face plate. Immediately after pulling the face plate off look behind the pivoting frame at the orange colored ribbon, you should only be able to see a small portion of it. If there is any sign of a yellowy residue its a sign that the protective covering of the ribbon is deteriorating. A bad flex cable is everything on the moving face plates.
Sep 06, 2008 | Kenwood KDC-716S CD Player
Answering Delay.
get a TORX 6 screwdriver
WIggle the tiny flex cable connector
near the hinge.. still no luck ????
Buy another V220 on ebay
gently take the phone apart and sub in the whole
screen shell and front of keypad.
DO NOT TRY TO remove the screen from the body section..
you will destroy to the teeny tiny flex cable.
Google for V220 take apart/ disassembly
Jan 18, 2008 | Motorola Mobility V220
Faceplate
Found this on Howard Forums. Sorry no photos.
CHANGING HOUSING/FACEPLATE:
Take off your battery, unscrew the screws on the back of the phone with a T6 screw driver.
Pry off the back plate,lift up circuit board gently(be mindful of flex cable) remove the flex cable from mail board by lifting brown part by the connector,
Unscrew then next 2 set of screws(be careful of flex cable!) remove the LCD board from the faceplate.
Now put the LCD Panel into the new faceplate. Find the new back slide and put your sliding rails on.(you may also put the slide magnets on from the old housing) carefully thread your flex cable through the opening.
Snap the Back slider on and then screw in the screws, then take the keypad housing and screw it into the slide rails.
Reconnect the flex cable by putting the brown hatch up(gently with finger nail) gently feeding the cable into the connector until the white line is about to the end of the connector.
Then put the brown thing down and apply little pressure.
Put the mail circuit board back into the phone with the headset jack going in first.
Then snap it back into place.
Transfer your speaker over the the new back housing with the prongs facing up.
Then screw on the back housing.
Replace battery and your DONE!!!
Best of Luck.
Please RATE my solution BELOW.
Nov 25, 2007 | Kyocera Slider Remix KX5 / Sonic Cellular...
Motorola v220 blank outside screen
take it apart
Oct 16, 2007 | Motorola Mobility V220
White screen
Your flex cable has most likely gone bad. If the phone is under 1 yr. old I would suggest have it repaired by a warranty repair facility. If you are going to try replacing yourself let me know, I will try to help w/ disassembly. Good luck.
Sep 11, 2007 | Motorola Mobility E815
RE Blank screen
Aug 22, 2007 | Motorola Mobility V220
Motorola Mobility MING A1200 Logo
82 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Motorola Mobility
Motorola Mobility
David Payne
David Payne
AJMAL KHAN
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
