Question about Lavazza Espresso Point Capsule Machine
Lavazza point espresso machine
Sometimes my espresso machine the water doesn't go through the pod and spills all over does the the machine melt the top of pod so water flows through or are the holes poked through by the factory
  • rcaruso1972 Jul 23, 2008
    need help with my lavazza point espresso machine
    Problem Solver:
  • 10 Answers
Sounds like you're in need of a new chamber and possibly some thermostats. For service you can call 781-393-2929, we are an authorized Lavazza distributor and repair center.
Posted on Aug 25, 2009
Water leaks into pod drawer and not much espresso comes out
The brass plate shown in the box must be free to move up and down about 1/8". Here it is in the down position pressing against the pod to make a seal. If yours is stuck in the up position, the water will go over, rather than through the pod; and drip into the tray. Access is easy. Remove the top. Then take out the 2 phillips screws behind the door which hold the front panel with door and lights. Gently lift the panel up and out of the way. Run the machine to see if this is your problem. If so, free-up the plate by using a screwdriver to pry it down, and a piece of wood to push it up. Repeat this several times.
May 12, 2015 | Lavazza Espresso Point Capsule Machine
I have a Gaggia classic and want to use pods. I've got Illy ese pods and the right (one hole pressurised basket) but still get just brown water. Can anyone help please?
I HAVE BEEN USING THE GAGGIA CLASSIC FOR 34 YEARS AND I ALWAYS BELIEVED THIS MACHINE IS BEING DESIGNED FOR SPECIFIC COFFEE QUALITY. THE ILLY ESE PODS ARE NOT FOR THIS MACHINE, TRY LAVAZZA PODS INSTEAD THAT IS SHAPED PERFECTLY WITH GAGGIA FILTER HOLDER FOR PODS.
Sep 07, 2014 | Gaggia Classic Espresso Machine
Lavazza 2100
You could avoid this problem by flashing water out without any capsule in. In anycase is a simple problem, you need to disasemble the machine and remove the head shower and wash it from dry coffee liquid which is blocked all the showers holes.
Jun 22, 2012 | Lavazza Espresso Point Capsule Machine
Clogged mchine capsule seems to overheat and melt
It sounds like you have a lavazza blue machine rather than the Espresso Point which is pictured above. In all cases contact me at www.lavazzarepair.com
Oct 11, 2009 | Lavazza Espresso Point Capsule Machine
Need service on lavazza blue LB 2210
For more company or product information please call us at 800-524-2343 or email us at info@betson.com
Jan 04, 2009 | Lavazza 2210
Can't get a full cup of coffee
First, you should not be using your espresso machine as an american coffee maker. It puts way too much pressure on the components of the machine. The standard cartridges are made to do 1.5 - 3.0 ounces of espresso. should you want to make a longer cup of coffee you need to get the aroma point gran caffe cartridges, lavazza code 427. this will enable you too get the longer cup of coffee without putting the added stress on your machine. Also it sounds like your machine mighy have a problem with the volumetric device. are you getting water in the capsule ejection drawer? should you want service you should call 781-393-2929. we are an authorized lavazza distributor and repair center.
Oct 09, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza espresso point
Did you fill it with water? are any of the lights blinking?
Jan 02, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Capsule Machine Logo
444 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
