Gear easily worn out on Toshiba e-studio45
Good day!
The copy has been alright but occasionally the page darkens, what we do is we clean the screen and the corona wire near the drum because it also darkens.
I have another problem because the small gear (21 teeth) on the developer easily worn-out. I have just replaced it last june and it has worn-out in a month time. Does the gear worn-out easily or there is a reason why the gear easily worn-out.
I hope you could help me again. Thanks.
Looking for geares for a toshiba 2532 turbo part numbers 4402810440 and 4402810280 anyone ?
Posted on Aug 04, 2008
  • 1,326 Answers
The dark copies could be that you need to clean your optics aswell, they are under the copy board glass. If the mirrors are dusty you will get alot of back groud in your copis and poor C.Q. I would just use a dry cloth to wipe the mirros off, should be three. Also, I would use a cloth with a little alchol on it to clean the lamp.. Almost forgot turn the copier OFF first. The small gear could be that there is another problem with the developing unit.... There may be a worn out bearing or seal... It should last longer.. Is this the second time it will need replacing? If so you may have to look alittle deeper
Posted on Jul 25, 2008
Toshiba 2540 copier image issue
It may take replacement of the toner cartridge and some cleanup to get it working again. Remember that new toner cartridges are sealed and that seal is removed at the time of installation. A cartridge that has been idle and unsealed for some time is likely to be no good
Jun 11, 2013 | Office Equipment & Supplies
My Toshiba e-studio 45 displays "close duplexer cover" and stops there. The cover sensor is fine. The circuit is open somewher-where?
Hello
I encountered the same problem a few years back, I found the power supply to be faulty.
You can try checking all the fuses on the power supply.
Sorry that is all i have at the moment.
I will see if i can download the pcboard repair manual.
Please let me know where i can email it to.
Regards
Apr 26, 2011 | Toshiba E-STUDIO 450 Copier
Toshiba e-studio 45
you must have to change primary
Aug 05, 2008 | Office Equipment & Supplies
Problem on Toshiba e-studio45
Yes, that could give you dark copies on one side of the copies... I use a glass cleaner to clean of the primary charge roller or grid. wipe them off with out getting any thing on the OPC drum it self. Did you clean the optics already?
Aug 04, 2008 | Office Equipment & Supplies
Gear Toshiba e-studio 45
1-Can you turn the developper by hand? if no ther unit is starting to go bad, usually the bearings and seals need to be replaced ( I did it maybe three times and refused to ever do it again, they hardly ever work even when rebuilt, and very messy.
2- the recovery blade,( where excess toner is suppose to go, is failing)
Jul 23, 2008 | Office Equipment & Supplies
Problem with gear of Toshiba e-studio45
I beleive it is compasating for the drum, you can change the corona wires( it is not difficult, but there is a certain skill and dexterity to it) you can find the wires at Radio shack or Ace, I beleive.
I'm not sure of which gear you are refering to, please clarify. TNX
Problem on Toshiba e-studio 45
That should be looked at by a technician to check the optics out
Jul 13, 2008 | Office Equipment & Supplies
2 possibilities -
drum or drum blade going bad
Open machine and look inside the drum is the shiny cylinder( do not touch) do you see a black ring around it? replace drum blade if yes.
Hi this is messay from ethiopia
where has this error appeared? ie. is it on the screen of the copier? is the spanner showing? did it print out the error when you try to print from the computer?
May 07, 2008 | Toshiba E-STUDIO 211C Copier
55 people viewed this question
k24674
jasbo
jasbo
