Question about RCA Universal Remote Control
Programing my new remote
I go thur the step on getting to on/off key to stay lite. I get ti to lite and go thur the codes for A emerson tv. None of the codes work. What do I do next?
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): Programing my new remote - clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
I recently purchased a "TDE SYSTEMS" jumbo
sanyo tv codes are 0506,0311,0612,0002,0428,0802,0412,0619 and emerson vcr are0626,0126,0826,0227,0327,0630,0632,0134,0037,0625,0924,0324,0128,0228,0428,0528,0447,0247,0724,0325,0526,0726,0027,0527,0827,0927,0628,0530,0830,0731,0634,0735
Dec 13, 2010 | Televison & Video
I need a remote code for an emerson tv/dvd combo. I can use my RCA universal remote to control the TV, but I can't find a code that works the DVD player. The TV is an Emerson LD 195EMX
The DVD codes are ..008,009,010,013,015,020,023,027,034,041,042,047,057,062,065,067,068,070....TV...011,026,027,028,029,030,031,032,037,042,053,064,065,067,075,076,079...Turn the device on you are programing, press and hold the CODE SEARCH button, press and release the device button, enter one of the three digit codes for that device, release CODE SEARCH button, press the POWER button, the TV should turn off, if not, repeat the steps using a different code until it does.....hope this was helpful...
Jun 01, 2010 | RCA Universal Remote Control
I HAVE A NEW BLC320EM98 TV AND NEED TO PROGRAM TV REMOTE TO WORK ON "COMCAST CABLE". None of factory codes woek. What does?
In your packet there should be a set up sheet for the remote when you try to set it up follow the search guide for the remote to search and find the comcast box. Depending on how the search works on that remote it may take some time and you may find more than one setting that will work. Then you have to choose the best one that operates the comcast box the best. Good luck and be patient.
Oct 14, 2009 | Televison & Video
Need additional remote codes for emerson tv - codes listed on
Hi if you haven't already, try these codes: -
000, 127 or 141
Sep 07, 2009 | Hughes HRMC11 Remote Control
Remote control code for Emerson LC200EM8
Have you tried the searching for your code option on the 15-2147?
for example, turn on your Emerson LC200EM8( press the appropriate key on your remote, if this is a TV.#1.press the tv key on your remote)..#2.Press and hold the little 'p' key till the LED lite,on the remote, blinks twice..#3..then enter 9 9 1.(the led should blink twice).#4.Aim and..Press the Power off on the remote....(the remote will start sending IR codes from its library to the selected device, starting with the most popular.)#5..If the TV responds go to step 6..if not, press the CH+ button, until it does...step #6 when device responds, to lock in the code, press 'p' once, the LED blinks twice.
Once you have your number locked in,,,you can get the remote to tell you what sequence the code is in by #1Press the appropriate key on the remote.(i.e, TV press the TV key ....Dvd player or VCR, then press that key). (Note: make sure you are aiming the remote at the device so the IR(infrared) enters the device.) Step #2 Press and hold the 'p' key(upper right corner of controller) until LED blinks twice, then release....Step #3 enter the code 9 9 0 ..the LED lite blinks twice. ..Step#4 to get the first number of the code press th e number 1 on the controller...the LED will blink the once for 1 //twice for 2...three times for3...etc...write down how many times the LED blinks(if it doesnt blink the first number of the code is 0) Repeat step #4 to get the remaining numbers, i.e. for the second mumber of the code enter 2...third number enter 3...till you have all four numbers.( when done you can press a different device key to get you off... then press the right device key for your device to operate it remotely. Hope this helps
Aug 31, 2008 | Radio Shack (15-2147) Remote Control
Having problems programing rca remote
Try these codes for Emerson TV: 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, 0185, 0282
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
Line up your original remote and the head-to-head before completing the following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 22, 2008 | RCA Universal Remote Control
Emerson remote for emerson tv/vcr combo
Emerson TV codes 0154, 0236, 0463, 0180, 0178,
0171, 0623
Emerson TV VCR Combos 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Nov 14, 2007 | One For All URC-3021 Remote Control
Emerson Remote with Philips TV
I like using original = part # 312814713331   cost 35.00.
Or go on-line to Emerson ? remotecontrols.net? ......T,
Oct 24, 2007 | Philips 27PT8419 27" TV
Televison & Video Logo
23 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
