Question about HP Photosmart C5180 All-In-One InkJet Printer
Black ink cartridge
We just replaced the black everything looks like a go but no black ink is coming out. I checked to make sure it was installed correctly. Brand new not remanufactured or ink filled
    Sniper:
  • 95 Answers
I understand that you are unable to print in black.
Please perform the following steps:
a) Turn the printer on.
b) Open the printer’s top cover.
c) After the print cartridges have moved to the center/home position of the printer, unplug the printer’s power cord from the electrical outlet.
d) Remove the print cartridges.
e) Using a dry, lint-free, clean cloth, wipe the print cartridge contacts, from the top to the bottom
f) The contacts inside the printer may also require cleaning. Using a dry, lint-free, clean cloth, gently wipe the contacts, from the top to the bottom
g) Plug the printer's power cord into the electrical outlet.
Once the steps are done, please do not insert the cartridges into the printer.
Perform the following steps:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Please re-insert the cartridges and check for the functionality of the printe by printing any document or making a color copy fromt the front panel of the All-in-One.
Regards,
Sagar.
Posted on Jul 27, 2008
My TX550W ran out of Black Ink (T103) and I replaced it with a Genuine Epson Cartridge compatible with my printer (73N), My computer status monitor/ink check on the printer shows the black ink is now full...
Sometimes the ink does take a while to come from the cartridge to the print head. Performing 1 head cleaning procedure may fix this. But only do this once, anything after is just wasting ink. Also make sure no part of the air tab sticker has blocked the air hole in the cartridge. Have a look at the new one you have to find the hole. Its just under the sticker you take off before installing it into the printer.
I hope this helps Regards GM
Apr 10, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I installed a new black ink cartridge and it doesn't work.
  1. Open the cover of the Kodak 5300 printer. Take out the cartridges that are to be reset.
    Find the filing hole. It will most probably be somewhere on the bottom or the rear of the ink cartridge.Moisten the syringe's needle and push it into the sponge all the way through the filling hole. Make sure you do not apply too much force, as the sponge will likely rip apart and consequently will cause clogs.
    Keep the ink bottle on a stable surface. The syringe's needle is usually very delicate and thin. Slowly, squeeze the ink bottle to make the ink flow into its sponge. Again, do not apply a lot of pressure or the sponge might expand, which will cause the ink to come out disproportionately during printing.
  2. Squeeze the ink into its sponge until it starts to look moistened. Make sure you do not fill up too much.
  3. Use tissues for wiping the filling hole. Install the refilled ink cartridge on your Kodak2_bing.gif 5300 printer. You will hear a click when the cartridge installs at the right place.
May 02, 2010 | Kodak 5300 All-in-One InkJet Printer
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
Print, particularly black, is inconsistent. Keep
Follow www.kodak.com/go/itg and try the step by step solution.If issue persists,Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy.
Dec 24, 2009 | Kodak ESP 5 Printer
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
Officejet d135 says bad black printhead- Replace the pentagon --
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 26, 2009 | HP OfficeJet D135 All-In-One InkJet...
I just replaced the 5pgbk ink but it wont print any black. i've performed the cleaning and deep celaning and all that stuff. everything else is working fine. just the main black ink wont work. i'm new at...
Aug 19, 2009 | Canon PIXMA® MP530 All-In-One Printer
Prints purple instead of black on photos only
My Canon printer has TWO slots for black ink cartridges. I assumed one was extra and didn't replace it when I ran out. Text printed just fine with only one installed, but my photos were printing with purple instead of black. I looked into it, and the two cartridges are different: one holds dye-based ink, the other has pigment based. Photos must require both kinds. If your printer is the same as mine, use both!
Jul 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
The printhead has a problem (after replacing the yellow/black ink cartridge with HP ink).
Try to clean the printhead manually ,
Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Black line the length of page
Please then try these to print:
Jan 27, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
56 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
