Thermostat ? no matter what temperature is selected, the compressor keeps running and doesn't cycle off.  compressor shuts off when just fan is selected, but cool mode just keeps chilling.  unit is six months old. energy saver does not work. unit just keeps running.
  • 1 more comment
  • ljm52381 Jul 23, 2008
    keeps running after room is good and cold.
  • VRODG73 Jul 23, 2008
    I'M HAVING THE SAME PROBLEM. THE COMPRESSOR RUNS CONSTANTLY. I THINK THE THERMOSTAT ELEMENT IS WORKING DUE TO MY USING AN ICE CUBE ON IT AND THE CLICKING NOISE IN THE REOSTAT CHANGES AT THE MUCH LOWER TEMP, BUT THE COMPRESSOR KEEPS RUNNING COLD TO THE POINT I HAVE TO MANUALLY CONTROL IT.
  • B Carson May 11, 2010
    Does it keep running after the room is good and cold, or does it run and not cool the place?
  • 143 Answers
I'm thinking the bi-metal is working, that's why you can hear a click, but the contacts are welded together. The bi-metal doesn't have enough strength to break the weld. Time for a new thermostat.
Posted on Jul 23, 2008
My domestic rv ac unit reaches the temp setpoint and the compressor shuts off but not the fan, it just keeps on running. Is this normal or should the fan shut off also?
Set fan setting to auto and not high or low setting. Fan will cycle with compressor after setting set to auto or " au" if a digital thermostat.
Mar 21, 2015 | Dometic Rooftop RV Air Conditioner
COMPRESSOR RUNS A LOT
Your model has a mechanical thermostat inside the control panel. I believe you have something else going on like a bad fan, start relay, capacitor. Something is causing the compressor to struggle to keep up and in turn causing the compressor to short cycle. If the thermostat has no control over run time then something like I explained is causing the problem. Here is a parts manual=> ED5VHEXVB04 Contact me if you would like my help, Thanks Sea Breeze
Feb 26, 2013 | Whirlpool Refrigerators
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon
Sep 07, 2011 | Westinghouse Dishwashers
Dometic unit cools great but compressor does not cut off when desired temperature is reached. The thermostat is on wall. The fan will cutoff at proper temperature but the compressor keeps humming and...
Hi, as you know the thermostat controls the unit. Here's what you need to do first. Go to your thermostat on the wall, pull off the cover. You are looking for the main control wires that come in from the back to connect to the screw terminals. Don't be afraid of shock as these are millivolt wiring connections.You say the fan shuts off but the compressor keeps running causing it to ice up. You need to get a screw driver and disconnect the wires from this stat. This should cause the compressor, fan, and all to shut down. If it does, you know that your thermostat is faulty and you will need to make your self a drawing on the wire connections, remove the stat, and you can get a new one at a RV sales and parts house.Find your breaker box where your main wiring comes in and shut off the a/c breaker if you like. Now, if the compressor keeps running after you disconnect it from the thermostat, then somewhere from the stat to the controls on the top have a hot wire that is touching somewhere causing the compressor to be energized all of the time. If you can go up top and find where this thermostat wire comes in, look it over good to see if the red is touching the yellow wire some where. I believe you just have a faulty stat at this point. Do what I asked on the stat, disconnect it completely, and we will go from there. You can get back to me by leaving a comment under my user name. Please let me know and we will take care of this problem.
Sincerely,
Shastalaker7
A/C, and Heating Contractor
Oct 01, 2010 | Dometic Rooftop RV Air Conditioner
I have a camper with a Dometic rooftop air conditioner. The Model No. appears to be 3310700.012. The thermostat it the type that fully shuts off the unit (compressor and fan) when the set temperature is...
no both the options A and B which you gave cannot be done.yes option B is possible in some form.but in this case fan will not shut down and this will burn the fan motor and even make the fan wirings short/.so option B is also not advisable.but the problem is either in the thermostat or in the thermostat shut-off relay.the voltages needs to be checked by meter to confirm the fault. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Apr 15, 2010 | Dometic Rooftop RV Air Conditioner
I keep hearing water running into a tray underneath my refrigerator. Is this normal?
Yes it is normal, that is the sign that your refrigerator is running just fine.
When your refrigerator start running, you set the thermostat to a certain temperature, your refigerator will automatically shut off once it reaches the temperature you desired, that is giving the chance to rest your refrigerator for a while, during this shut off period, it will melt some ice, the water will go directly to the tray below your refrigerator. once the thermostat sense the the coldnest inside the refrigerator is slow vanished then the compressor will start again to attain a certain temperature.
that cycle keeps repeating that procedure
Nov 05, 2009 | Maytag MSD2542VE Side by Side Refrigerator
WHIRLPOOL NO-FROST REFRIG/FREEZR MODEL-EHT201ZKWR5
looks like operating normally...
the fridge as it reaches it's temperature shuts the compressor off and then after a few minutes..the fridge would increase temperature again and would turn back the compressor again.
its the thermostat which is cutting on and off the compressor.
and i think it is normal. based on the temperatures that you indicated..it is cooling very well..0 F in the freezer and 40 in the refrigerator... that's good.
drcool
Nov 06, 2008 | Whirlpool Refrigerators
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Heating & Cooling Logo
208 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
