Question about Pentax Optio M20 Digital Camera
Camera shut down with lens out, won't come back on
I was taking a series of photos at a tennis match using the zoom and the sports mode. suddenly the camera died, with the lens sticking out. new batteries did not help, nor did removing the memory card. it will not turn on and the lens is extended.
  • 797 Answers
Some problems with cameras cannot be solved without taking the camera apart and checking everything.
Sorry to say such a problem may tell you that it is time to sell the camera for parts.. on a website such as Ebay for parts, repair, or AS IS.
Okay, that said, You can try something which may or may not help.
Take the camera in your hand and hit the edge into the palm of your other hand. You may also try this.. put a doubled up towel on a table or desk. Then take the camera in your hand at an angle an "bump" it onto the desk or table where the towel is. This may shake up the system inside to cause the connections to work.These could damage the camera even more, but because it is not working anyway, you may gain.
Of course this may not always work, if something is really wrong with the inside system or wiring.
Posted on Jul 26, 2008
Digital zoom and micro focus won't work
Different scene modes allow for different functions. I rarely use them due to this. You have to set the scene mode to take a normal photo. Meaning in Fireworks scene mode you cannot take macro photos because the lens is focused to infinity already and is locked this way.
You also may have some problems with material in your lens. (I am not sure) If you get your scenes straightened out and it still does not work I would suggest searching for lens error and look for solutions there.
Nov 26, 2017 | Nikon Coolpix S6100 Digital Camera
Zoom on nikon d5100
In either mode, you're zooming by turning the zoom ring on the lens? In live view mode, if you zoom in by pressing the magnifying glass button, all you're doing is zooming the display, not the image itself.
Feb 26, 2013 | Nikon D5100 Digital Camera with 1855mm...
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
I have a Canon EOS 550D camera fitted with a Canon Zoom Lens EF-S 18-200mm lens. I bought both together sometime early in 2010 from London Camera Exchange, Nottingham. I am not in Nottingham at the moment,...
Just a thought - are your Image Stabilizer and Auto Focus switches On or Off?
Might be worth experimenting with them.
Otherwise, sorry, can't help.
May be necessary to contact your vendor.
Aug 09, 2011 | Canon EFS 18200mm f3556 IS Zoom Lens + UV...
All of a sudden I get a dark brown area in my photos. Lens has always worked beautifully. Now every photo i take has a dark brownish goldish stripe across one side or down the middle.
Check it with other camera because it is possible it is not your lenses fault but your cameras. Check the back side of the lense for any fingerprints or marks or ect.
May 02, 2011 | Nikon 17-55mm f/2.8G ED-IF AF-S DX Zoom...
Camera shuts down when 'zoom lens' is used.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Jun 10, 2010 | Kodak EasyShare C913 Digital Camera
Shuts down while using the zoom lever
see this thread :
http://www.fixya.com/support/t225803-canon_powershot_s3_switches_off_when
Mar 21, 2008 | Canon PowerShot S3 IS Digital Camera
Zoom Lens projects out and camera is shut down.
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Dec 18, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Shuts off when I zoom or take photo
Sounds like zoom has sand in it, Or the camera may have taken a hit to the front of the len's, Lens has to be taken apart, Has to be done buy a camera repair shop/or factory. TC
Aug 25, 2007 | Fuji FinePix E500 Digital Camera
Coolpix 8800 shuts down
Make sure to use good NiMH batteries. Another possiblity is a problem with the card. Borrow a card and see if it has any effect. check to see that the pins in the card slot are all aligned, none out of place. check that the card door and the battery door close firmly, with some pressure. The camera can shut down when it has a problem detecting that the doors are closed. When it does turn on, play with the zoom without taking pictures, zoom in and out, if during zoom the camera shuts down then you might have a lens problem, something is malfunctioning in the lens mechanism and the camera shuts down to prevent damage. Good luck
May 19, 2006 | Nikon Coolpix 8800 Digital Camera
Pentax Optio M20 Digital Camera Logo
44 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
