Question about Dryers
Speed Queen gas dryer won't heat
I have the commercial model of a Speed Queen gas dryer. The ignitor glows and I just replaced the thermostat #510702 and it still will not ignite. There is gas flow to the valve. I noticed that on the exhaust housing there is another thermostat which is linked to the one near the ignitor. Could this be the source of the problem?
Thanks,
Mike
  • wiskycorgi Aug 04, 2008
    I have an older speed queen gas dryer that does not even glow. I got a igniter assy but it is flat and does not look like the one that is in there which is round. How do I remove the old one and will the flat one work?
  • Anonymous Mar 18, 2014
    How to replace belt
When we start dryer after certain minutes the fire flame goes off so one time we change the front switch but still it's continue so what i can do?
Posted on Sep 08, 2013
    Genius:
  • 1,028 Answers
Probably not most likely bad coils on gas valve the 2 black dohickys with wires
Posted on Jul 23, 2008
Model AGSZOAWF gas dryer will not heat up. I would like to just replace the necessary part or parts myself (or with the help of my brother) I dont know where to begin taking the back off? There are a...
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Speed Queen AGS28AWF Gas Dryer
My speed queen dryer model #AES68AWF doesnt heat what could it be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 16, 2011 | Speed Queen AES68AWF Gas Dryers
No heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 31, 2011 | Speed Queen Dryers
Dryer does not get hot
heatman101
Dec 28, 2010 | Speed Queen AES28AWF Electric Dryer
Dryer works but no heat,
heatman101
Oct 21, 2010 | Speed Queen AES17AWF Electric Dryer
My dryer starts and runs but wont heat up
heatman101
Sep 21, 2010 | Speed Queen CGS68AWF Gas Dryer
My speed queen gas dryer comes on but will no longer heat. The igniter is fine.....passes the Ohm test. What might be the solution? And what are the est. part costs....this is an old speed...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It works on amps... not ohms...
heatman101
Sep 07, 2010 | Dryers
My speed queen AGS17AWF isn't getting any heat, a friend said that it could be the ignitor or fuse but I cannot find the fuse on diagrams and I don't know how to get to it based on the diagrams, any help...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 05, 2010 | Speed Queen AGS17AWF Gas Dryer
Dryer does not heat. Electric ignition does not "spark" lighting
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
I have a speed queen gas dryer. do i have to
It would be safest to turn off the gas supply. You should have a gas **** in line for this purpose.
Aug 29, 2009 | Speed Queen Dryers
Dryers Logo
727 people viewed this question
Top Dryers Experts
