Question about HP Pavilion dv9000z Notebook
How do i get my hp to work?
Ok i see most people have similar probs but mine wont start up i don't even hear the fan its like the blue lights are on but the screens blank and if i press volume or somthing it don't sound the same.. i mean it did drop this morning but it worked just fine all afternoon all i did was close it and when i cam back to use it i opened it like normal all the lights were on but no start up. i tried to plug a monitor to it but i still see nothing. its a dv 9000 17inch
  • 1 more comment
  • jerebaby Jul 23, 2008
    i tried to turn it on again but it still doing the same thing were the lights come on then it stays for a couple min and goes offf then comes back on again... my thing is if the impact did anything to it why did it work all day but only stopped working two hours ago?
    the laptop is not the old though olny about a year and i know there is nothing wrong with the charger because i just bought a new one plus the lights come on indicating thats its chaging
  • hyam100 Jul 24, 2008
    i have the exact same problem. it happened yesterday.. let me know if you find a solution.
    Scholar:
  • 106 Answers
Things die periodically. it may be just that it is truly fried.or it could decide to turn on again tomorrow. some computers are tempermental. also, if the battery whent then even plugging it in may not work due to the way most laptops are set up. try getting the battery replaced(the blue lights may just be running off the bios chip's internal battery for running the clock) if that does not work, then try getting a new charger for it. if that doesn't work... trash it. have the hard drive and meory removed for data or selling purposes and get a new laptop (preferrably the same type) and put the old hard drive in it. you can probably sell the ram and get quite alot for it.
Posted on Jul 23, 2008
  • HP Master
  • 2,794 Answers
It could be that the switch that closes the notebook might have been broken on the impact. See if you can turn it back on again. Then go into the control panel and find the settings that control the switch on your notebook computer that activates when the lid is closed. Set it for disable or no effect. Sometimes there listed in you power settings.
Hp pavilion modelp6510f press power switch on top of pc does not light computer fans blow but compute does not turn on
ok th p6000. complete range when they were made had to be recalled as they put the copper expansion pipes ran across the gpu & cpu hence a massive overheat problem. they put copper shims over the cpu & gpu but this worked for a short time but it was inevitable and both units ended up being cooked i had this problem with mine. so if you have tried external monitor with no images it would sound or more likely to be the gpu cooked sorry for the bad news.
Jan 28, 2014 | Computers & Internet
Error why coming
Can you hear any fan or drive sounds? If you don't hear anything at all when you try to turn the laptop on, no little LED's light up, the problem almost certainly isn't related to the hard drive. So if you don't have a live screen, start with the LCD troubleshooting flowchart, and if you don't have any activity at all, start with the power troubleshooting flowchart. Even if the hard drive has failed at the electro/mechanical level and won't spin up, this wont prevent the LED's on the laptop from lighting up, or the LCD from displaying the BIOS information and complaining about the lack of a boot device.
Ford F150 Body Kits
Jun 07, 2012 | Computers & Internet
Hp compaq 7620s wont start ( constant blinking blue light )
The adapter output appears correct, the batteries often work in that voltage range. But the problem you have is the motherboard, the HP line has constant trouble with the main board, only option is board replacement.
May 12, 2012 | Computers & Internet
Hp pavillion televisions' blue light blinking and wont turn on. no sound or picture just turned off and wont turn on
CK your Fans if they stop running set will shut off other wise replace the Lamp call fox 1-800-227-5369
make sure your Lamp Fan is OK if you need Fan call Encompasss Parts 1-800-638-3328
Dec 21, 2009 | HP Pavilion MD5020N 50" DLP HDTV
I have an hp Zd7000 that wont start i can hear it trying to.
Did you try the FN+screen switch key. maybe check to see if nothing is loose ( hdd, ram ) also the bios to see if screen settings are correct
Oct 01, 2009 | HP Pavilion zd7010us PC Notebook
Audi A6 radio intermittently cuts out
I've had similar problem with AUDI A6. AUDI replaced phone controller, covered by 70% by manufacturer. Total cost 400 Euros, repir was done in Germany.
Aug 27, 2009 | 2006 Audi A6
Hp dv9000 wont start up
This could be a couple of things. Start by checking the memory. Make sure they are seated properly and didn't slide or shift a bit in the fall or the sudden stop at the end of the fall. Then remove the memory and try them one at a time. A bad memory chip is the number one cause of this. If it still won't start, then I'm afraid that you may have damaged the motherboard. HP seemingly has the most fragile motherboard on the market. I've had two HP laptops through my shop this year that were dropped, one while walking through the house on carpet, and the other from the sofa cushion to a carpeted floor. Both had hairline fractures in the motherboard, both ran for a period of time until they heated up a bit and the motherboard expanded, opening the crack. One would continue to run if you let it cool overnight, but then would stop again after heating up. The hairline fractures could be seen when holding the motherboard up to a bright light. If the memory checks good, then you may want to take it in for a professional diagnostic, they will be able to tell you whether it's the board or a replaceable component.
Jul 23, 2008 | HP Pavilion dv9000z Notebook
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
HP MD6580N Rear Projection TV
I have exactly the same problem with mine.
HP refuses to help and no TV repair person will even bother coming out if I tell them my TV is an HP because their service for parts and tech support is brutal.
Can anyone help?
Jun 16, 2008 | Televison & Video
Spinmaster 3 wont light up
the problem seems to be with the relay that switches on/off the lamp it seems not to be able to handle the current ant the contacts burn out... just check the side of the relay for melting/burning i have replaced mine with an uprated one with no probs
Nov 27, 2007 | Office Equipment & Supplies
HP Pavilion dv9000z Notebook Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
