Sony 36 tv sound 20 sec thenquits has no picture hv seems to do the sameopened set
Opened set sound +hv 25 kv come on for 20 sec.then both quit.im aold retired x tv service guy last tv rep was 30 yrs ago.new tech stuff throws me. maybe u guys have some tips for me. im 75 yrs still trying , thanks for listening. gacaddy@aol.com
  • gacaddy Jan 03, 2009
    Thanks Dan. The set is a Sony KB36 HS 20 . It flashes code 4---4---4---continuously. It comes on with sound, no picture, but, has 24 KV HV. I notice a slight brightness flash in the lower right corner of screen but no picture or brightness anywhere else. After approx. 30 seconds, a relay clicks and sound and HV quit. If I press on the same thing will happen exactly. The relay sound and HV quit. This will continuously happen its a loop. Set was playing excellent. I am wondering if I should just junk the set, or is it worth working on it. Do you have an answer to the issue?? The set weighs 240lbs. Its a monster but its only 4 years old. Please let me know any ideas you may have that could help me save the set, or let me know if I should get a mover to haul it to the trash heap.
    Your help is always greatly appreciated.
    This Old TV Repairman wishes it was like the old days with tubes and wires vs. bells and whistles.
    Jerry/ GACADDY
  • 4,234 Answers
This set should have the standby light blink a code number,pause number. Can you please post that count and the model number? With that I should be able to assist.
Thanks,
Dan
Posted on Jul 23, 2008
  • ABRsvcs Jan 05, 2009
    Try replacing C6532 which is a .056ufd 800V cap located off of pin 3 of the flyback. This cap often goes open and can cause this.
    Let me know the results.
    Thanks,
    Dan
Have sound but no picture. Turned TV off last night and when I turned the TV on this morning there was good sound on all channels, but there is no picture. Just a black screen
is hv circuit problem a power transistor to 25KV transformer maybe dead, check the HV Circuit, or 1XXV output from Mains transformer the fuse maybe dead
Mar 11, 2010 | Sony KV-36XBR450 36" TV
Hi, my name is Nicole. My KV-36HS510 Sony TV is being broadcast with the picture size reduced quite a bit. Playing DVD's is fine, the pic fills the whole 36". However on cable TV it is chopped on the...
press "menu"
the setup screen should open
scroll through the options to "16:9 enhanced"
you should find 2 options ("on" and "auto")
choose "auto"
that should do it
enjoy.....
Sep 12, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony KV-32S45 turns on at first, than blinks out, still sound
I would look for intermitent solder connections on the small horizonal driver transformer as well as other HV Componets.(HV Transformer etc.) Also solder up the Vetical output IC. These have been common causes of failures. I would not use the set until these have been checked and soldered. If you don't, a massive failure of the hoizonal circuit and powersupply will occur.
Hope this helps,
Skyassoc
Jun 18, 2009 | Sony KV-32S45 32" TV
Sony KV-36xb1400 convergance Problem
Its not matter of service code only. You also need service data to fix it. But question is, how data is being corrupted? It seems hardware failure in your TV set.
Jul 31, 2008 | Sony KV-36FS100 36" TV
SONY WEGA KV-32XL90E
Hiii...
what chassis your tv set ?
Thank's
[Vrya]
Jan 23, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
PROVIEW 19" LCD TV - FLATSCREEN - KV SERIES
I have same problem, im goin to try this fix i found on youtube.. different tv but same problem
http://www.youtube.com/watch?v=_0175VbmV9M&feature=channel
Jan 08, 2008 | Proview HV-207 20 in. HD-Ready LCD...
HV Sound no Picture
Sounds as though there is an intermitant, heat-related problem with the HV transformer. You can order this at a tv parts shop or from Sony (probably more expensive) the part number should be on the part or on a schematic. If not, the parts dealer can look it up from the model number.
Good luck! :)
Dec 27, 2007 | Sony KV-36XBR400 36" TV
Sony KV 36 xbr800
Hiii...
I'm not sure about the chassis number of your tv set..
but I can give a solution for your proble....
It might be the problem at A,B,M board there's no +5V or over voltage +5V...check the IC504 at A board looks like a ic regulator 5V..check c530(470uF/25V),check c540(1000uF/16V)..
Dec 02, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Oct 30, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony MODEL KV-2585 TV
You have your information incorrect, Q is not the designation for diodes, Q657 would be a transistor. First give us the correct number for the diode and how do you know it is shorted?
Aug 13, 2007 | Sony KV-36FS17 36" TV
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
