Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Wireless internet One wireless connection will work, another won't. Is there a way to find out our connection password?
  • Aris C.
    Aris C. May 11, 2010
    You mean only one wireless computer can connect at a time to your router?
    To check your wireless encyption key/password, you need to log in to your router's administration page.
    for older model the default IP is 192.168.0.1, for newer models its 192.168.1.1
    username and password is "admin"
    Scholar:
  • 34 Answers
You can follow the following steps to get the wireless password
1. Open IE in the address bar just type in www.routerlogin.com then press enter
2. Asking for login and password by default user name "admin" and password is "password"
3. On the left side of the page you can see wireless setting under setup.
4. Once you click on that you can see your wireless setting page
5. Scroll down that page and you can see at the bottom which security option is selected
6 It will show you key1 or passpharase
7. That is your wireless password or in any case if it is not visible in that case you can type a new password and apply those settings. But if you are changing you password make sure you required to reconnect with your all computer using the new password.
I believe that will help you to resolve your concern.
Posted on Oct 29, 2009
I have a D-Link router and when I try resetting it, the password won't work even if it's the default password
You may have to do a full factory resent. Try a hard reboot (turn off the on) of the router. If not try a factory reset that you should be able to do using the admin functions in the settings. Of course you will have to set-up you router from scratch but this may solve your password issue.
Apr 15, 2013 | D-Link DIR-815 Xtreme N Wireless 802.11N...
Connection problem on vigo tablet
Not a solution, but... we could not connect to Vodafone, as the Vigo was not compatable with our Vodafone supplied Huawai modem!!!!!
Dec 27, 2012 | Tablets & eReaders
Dell Inspiron Mini won't connect to wireless- won't ask for wireless password and therefore cannot connect. Help!
Learn easy Steps To Set-Up A New Dell Inspiron mini. If you need assistance with issue, Call immediately -18002044427 Dell Laptop Technical Support number, Read More http://www.delltechnicalsupportphonenumbers.com/blog/steps-to-set-up-a-new-dell-inspiron-laptop-for-the-first-time
May 08, 2017 | Dell Inspiron Mini 10 Notebook
New download of windows 7 won't retain or create internet connectins
Ok, this is conflicting... won't retain or create!! Doesn't it have to be created to retain it?
Did it connect before you downloaded windows 7? Exactly what happens when you try to get on the internet? Do you have the wireless switch on the laptop turned on? Do you see your wireless router? If so did you put the password in correctly? If not, it will never connect.
Jun 03, 2012 | Compaq Presario CQ62231NR Notebook
Can't connect iphone to dlink router
When my ipod tries to connect to my computer wirelessly, it asks for the password. I enter it, but it won't accept password. It finds the router ok, just says password is incorrect. I've checked and it's the right one. Any suggestions?
Nov 27, 2011 | D-Link DIR-615 Wireless Router
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
My router seems to be destroyed. i tried to setup access point but right after that the light went red.. but i connect wirelessly. and my fone and my sisters' laptop can't connect to the internet...
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
May 16, 2011 | Belkin Surf N300 Wireless N Router
Trying to connect to internet wifi and asks for my WAP? Isnt this just my password to join the internet... same as I use for connecting my iphone? It won't accept the password but I know its right.
It is trying to connect to a wireless access point and needs the password for that wifi access point not the password you use to go on the internet
May 13, 2011 | Vizio SV472XVT 47 in. LCD HDTV
Can not connect with my home computer.Router and modem working,just won,t connect
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 14, 2010 | HP Pavilion dv6000z PC Notebook
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
Jan 17, 2010 | NetGear WGT624 Wireless Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
37 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
