Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Akai replacement parts
The convergence is off on our akai pth5498 (rear projection) tv. i was able to locate the convergence board and get the part information off of it but cannot locate a replacement part. i am told that samsung makes akai and while i was in there, i did notice that several of the parts are samsung. does anyone know where i can locate replacement parts for my tv?
  • midcitie Jan 13, 2009
    need replacement screen for my akai PTH5498. Where can i get or find?
  • 4,234 Answers
You are not likely to find the board easily, but you should be able to replace the convergence ICs relatively easily. Look at the board. Try resoldering the pins on the STK ICs. If that fails to resolve your problem, replace the ICs. There may be some pico fuses located close by or low valued resistors that may be open. Check for those as well.
Keep us posted.
Dan
Posted on Jul 23, 2008
For my pth5498 the green and red colors are not in alignment. I guess I have a convergence problem. I hit keys mute 1 8 2 and then turned the power back on and then a menu came up. I got out of it and have...
Any colors R,G,B out of alignment the convergence board are dead.The tv convergencce board must have it 2 STK convergencce ICS,and some or all it resistors be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 18, 2010 | Akai PTH5498 54" Rear Projection...
Akai PTH5498
thats board i beleieve iff the unit has fuses on the amp board i beleive they are fb102b and fb101b fusables are you going to replace these.. more than likely if u still have partical convergence it may be a amp or a resistor not the fuse.. have you gone into convergence mode? does the read crosshairs move?
Dec 13, 2007 | Akai PTH5498 54" Rear Projection...
Akai pth5498
the part number for the convergence board is aa95-00705a and you can order it at www.vancebaldwin.com. send me your email addy to fixa@markservicepro.com and i will send you a wiring diagram....
Nov 02, 2007 | Akai PTH5498 54" Rear Projection...
Red and blue pic adjustments areso out of adjustment how can i get them back
Convergence board is dead.Go to Tv repair World.com buy a new convergence board replaced the board will solved ur problems.Samsung/Akai use same convergence board.
Jan 22, 2010 | Akai PTH5498 54" Rear Projection...
Convergence board is bad
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 28, 2009 | Akai PTH5498 54" Rear Projection...
Akai (PTH5498) 54" rear projection TV with red and green ghosting and large curve in the picture at the top and bottom of the screen. Unable to fix using manual convergence. Thinking it must be the...
Hello:
Yes is is your convergence IC's. One has gone bad, but consider replacing both of them because if one has gone bad then the other is not far behind. They are located on the middle board of your set. They are mounted on a large heatsink, the part # should be STK-392-040. Replace these and your set will work fine again.
Nov 15, 2009 | Akai PTH5498 54" Rear Projection...
I have a convergence problem with my akai PTH5498 REAR PROJECTION TV. Please tell me how and where I can order the part plus how to install it.
You need to replace both convergence ICs they are STK392-040 you can get replacement Ics at the following link and they provide free instalation instructions. Heres the link.
http://servicemanuals.vstore.ca/
Jun 04, 2008 | Akai Televison & Video
Akai PTH5498
A lot of people on this site have this problem, including me. Usually a problem in the convergence board, requiring fixing (not expensive, really) or replacement (about $80 DIY). In my case it was a coolant leak.
Mar 04, 2008 | Akai PTH5498 54" Rear Projection...
TV will not turn on...
Convergence board failure. $300 repair
Sep 19, 2007 | Akai PTH5498 54" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
576 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
