Question about LG DLE2514 Electric Dryer
Dryer tumbler stuck
I left the filter off now it wont turn i think something got stuck in it and i want to take off the front and the back. how does it come apart?
    Problem Solver:
  • 5 Answers
You have to actually unscrew the top starting from the back of the top, then lift the top off and you will be able to get to the screws that hold the control board which then will have to be disconnected, from there you will need to remove the front by removing the three or four screws from the front hidden by the door also removing the door and removing the screws at the top of the front under where the control panel was and the front of the dryer should tilt toward you and then pickup off the hinges that are on the bottom.
I hope this helps.
Posted on Aug 13, 2008
Kenmore model number 86863100 tumbler seemed stuck and now wont turn on
it's possible the motor is seized or the blower has something stuck in it and keeping motor from turning freely.
Oct 28, 2013 | Kenmore Dryers
I own a Bosch Nexxt Series Electric Dryer, the clothes come out with a petrolium smell, grease or something. I have cleaned the trap, duct work, bearing shield to no avial. It is not the washer, the
Instructions
Dryer Does Not Turn On
Ensure that the dryer's power supply cord is firmly plugged into an electrical outlet.
Inspect the structure's fuse box for a tripped fuse. Each fuse is assigned a single "On/Off" switch. If any fuse switch is in the "Off" position, flip that switch to the "On" position. If the problem persists, contact a professional electrician.
Press the "Start/Stop" button on the left side of the dryer's control panel.
Close the dryer door firmly so that the door clicks into place. The dryer will not operate if the door is not shut.
Lint Filter
5
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull the lint filter out of the dryer. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then reinsert the filter and close the door.
6
Turn the dryer off and allow at least 30 minutes for the dryer to cool, as excessive heat can cause a drying program malfunction.
7
Increase the ventilation of the room the dryer is located in, such as by opening a door or window. Excessive heat will cause the dryer to automatically turn off until it cools as a safety measure. Increasing the ventilation will help keep the dryer cool.
Clothing Not Fully Dry
8
Clean the moisture sensor. Open the dryer door to access the moisture sensor. The black-colored sensor consists of two bars, and is located at the front of the dryer's tumbler, to the left of the lint filter. The sensor should be cleaned with a clean cloth and white vinegar once per month.
9
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull out the lint filter. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then insert the filter back into the dryer and close the door.
10
Spin the laundry at a higher spin speed in the washing machine before placing the laundry into the dryer to reduce the moisture content.
11
Turn the dryer off and allow at least 30 minutes to pass for the dryer to cool, as excessive heat can cause a drying program malfunction.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
I bought it in 2003 neptune dryer and the 3 bar inside the dryer broke and the dryer is not working right . we have to dry them 3 time before they are all dry
Instructions
Things You'll Need:
* Phillips-head screwdriver
* Replacement belt
1. Disconnect the power cord of the Maytag Neptune dryer from the dryer electrical outlet.
2. Open the dryer door, and locate the four screws on the inside lip of the door opening. Use a Phillips-head screwdriver to remove the four screws. This will disconnect the front panel from the shroud assembly.
3. Grab the front panel on each side with your hands. Lift up on the front panel to unhook it from the retaining tabs on the side panels. Remove the front panel, and set it out of your way.
4. Use a Phillips-head screwdriver to remove the four outside perimeter screws that secure the shroud and tumbler front to the dryer cabinet. Pull the shroud and tumbler front away from the tumbler while lifting the top panel partially up.
5. Reach both of your hands underneath each side of the tumbler. Use your left hand to grasp the idler pulley, and pull it to the left while using your right hand to slip the belt off the motor pulley. Pulling the idler pulley to the left releases tension on the belt. You can now slip the belt off the back of the tumbler.
6. Take the old belt with you along with the model number of your dryer to purchase a new belt. Most appliance repair shops will have replacement belts in stock. Make sure that the new belt matches the old one by comparing the two.
7. Slide the new belt over the rear of the tumbler with the ribbed side pointed to the inside. Using both hands under the tumbler, route the belt around the motor pulley and idler pulley. Pull the idler pulley to the left while routing the belt, and carefully allow the idler pulley back to the right to apply tension.
8. Reattach the tumbler front and shroud to the front of the cabinet using the retaining screws. Place the front panel over the side retaining tabs, and push it down to lock it in place.
9. Open the dryer door, and secure the front panel to the shroud using the retaining screws. Close the dryer door, and plug the power cord back into the dryer electrical outlet.
Feb 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Tumbler belt came off
  • Unplug your dryer from the electrical outlet. Remove the lint trap by lifting its cover and sliding it out. Use a screwdriver to unscrew the two screws that hold in the housing of the lint trap.Lift up the top panel of the dryer and take off the holder for the door switch wire. Look for the screws that hold in the front panel of the dryer, located on top of the front panel, and unscrew them. Take the panel off the dryer by lifting it off.Look inside the dryer, find the broken dryer belt, and before taking it off, note the way it is routed around the pulleys, then take it off. Install a new Whirlpool dryer belt by slipping it around the tumbler with the grooves facing the surface of the tumbler. Ask an assistant to hold up the tumbler while you move the belt into the proper place, aligned with the black line around the width of the tumbler.Wrap the new dryer belt around the pulleys as noted in Step 3. If you don't remember how, or the old belt was snapped and not aligned properly, look at the dryer belt diagram in your user's manual.Align the front panel of the dryer with the tumbler. Put back in the two screws that hold the panel in place. Open the door of your dryer and with your hand, turn the spinner one time counterclockwise. Reconnect the holder for the door switch wire, being careful that it doesn't touch any moving parts.Use the screwdriver to carefully position the rubber seal along the back of the tumbler. Make sure the seal is on the outside of the tumbler and that none of it sticks to the inside of the tumbler.Slide the lint filter and housing back into place, and screw in the two screws that hold it in. Plug the cord of the dryer back into the electrical outlet and check that it spins properly.
  • Oct 11, 2010 | Whirlpool Dryers
    I have a Maytag MDE4700A electric dryer. It quit working (turning) but still heated up. I took the cabinet apart and found that the belt was broke. Need some assistance on beginner steps for replacing...
    Disconnect power to the dryer then open the door and remove the center screw of each hinge secured to the inner flange of the front panel in the door opening. Grasp the door with both hands and lift the door in the hinge area then draw the door assembly away from the dryer to disengage the hinges from the slots in the front shroud.
    Remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
    Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
    The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
    Disconnect the wires from the door switch, sensor bar, and the lamp holder then unsnap the lamp holder wire harness from the front shroud wire retaining clip.
    Remove the four perimeter screws holding the shroud and tumbler front assembly to the cabinet. Remove the lowest outside screw at each corner then the top screw on each side.
    Pull the shroud and tumbler front assembly out and away from the tumbler while slightly lifting the top cover.
    Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then grasp the idler puller with your left hand and pull the idler upward and to the left.
    Slip the belt off the motor pulley and the back of the tumbler then pull the tumbler out of the cabinet while lifting the top cover.
    Place the belt onto the outside of the tumbler and position it 1 1/2 inches in front of the rear baffle mounting screws with the ribbed side facing the tumbler.
    Position the tumbler into the rear felt seal and resting it onto the rear rollers then lower the front of the tumbler onto the blower housing.
    Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then locate the belt and create a small loop with your right hand, ensuring the belt is free of twist.
    Position the open end of the loop onto the motor pulley with your right hand. Grasp the idler pulley with your left hand then pull the idler upward and to the left to clear the drive belt.
    Relax your left hand and allow the idler pulley to rest down onto the belt. Grasp the baffles with both hands and rotate the tumbler clockwise for the belt to align itself.
    Reinstall the shroud and tumbler front assembly in reverse of the removal steps. Lift the front inner edge of the tumbler to allow the front of the tumbler to rest on the teflon bearings on the shroud and tumbler front assembly. Check the felt seal to ensure that it is outside the lip of the tumbler.
    Secure the top cover with the hold down brackets then push the front panel posts against the clips in the cabinet until it engage.
    Insert the door hinge tabs into the slots in the front shroud and secure the hinges with the screws removed previously to complete the procedure.
    Aug 22, 2010 | Dryers
    Frigidaire dryer hums when button is pushed in but won't start
    ok can u turn the tumbler freely,
    if no well there is something stuck in you blower like a sock or something
    if the tumbler turns freely
    keep the door open and hold the door switch
    try pushing the start button
    and tuning the tumbler, yes all three at the same time lol you may need a hand
    try tuning the tumbler when you hear a hum
    if it takes off bad news your start winding on the motor is bad or the capacitor depending on your model
    if it does not turn, but the hum continues longer than 1-2 minutes it could be just a belt
    Oct 19, 2009 | Frigidaire Electric Dryer
    Machine has stopped!
    Hi
    e120 isnt a code. could it poss be e20? which means block filter.
    is it leaveing water still in machine? if so remove filter and clear any debris if any and check impeller is turning ok.
    regards
    Mar 22, 2009 | Zanussi ZWD1680W Front Load Washer / Dryer
    Scraping noise with burning smell
    You quite possibly have something like a penny or a paper clip stuck at the heat duct. ***First-shut off the electric to the dryer***. From behind the dryer, remove the heat tunnel and clean it out. You will be surprised how much lint gets past the filter. It's an easy repair, just a few screws. While you're back there, look around for any buildup in other areas.
    Jan 03, 2009 | Whirlpool LEQ8000JQ Electric Dryer
    Put belt on dryerg
    While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
    1. Unplug the dryer or disconnect power.
    2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
    3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
    4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
    5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
    6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
    7. Reconnect the wires to the door switch, if you removed them earlier.
    8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
    9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
    10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
    11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
    12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
    Nov 16, 2008 | Whirlpool LER5636P Electric Dryer
    Broken belt that turns the drum
    12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
    Aug 17, 2008 | Maytag PYG2300A Gas Dryer
    LG DLE2514 Electric Dryer Logo
    56 people viewed this question
    Top LG Dryers Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    John Tripp
    John Tripp
    Are you a LG Dryer Expert? Answer questions, earn points and help others
