Question about Toshiba 23HLV87 23 in. LCD Television
Toshiba 23HLV87 HDTV
A black square, about half the size of the screen, appears in center of the picture. It can be cancelled momentarily by pressing the Exit button on the remote.The square can also be cancelled by pressing the Menu button, the Mute button, or the Input button. The square will remain out of sight as long as menu items are displayed, or as long as the audio remains muted.
How can I eliminate the black square?
  • 2,335 Answers
Click here to download the user's guide and go to page # 41 to turn caption OFF.
Black box on screen Select OFF in the Closed Caption menu to turn off the Closed Caption Text mode.
Posted on Jul 23, 2008
    Genius:
  • 1,226 Answers
Please try to unplug the TV from the wall outlet and then rest it for a while pulg it again and test. if still the issues remain then try to see the all the switch menu infront of the TV maybe lock or got errors.
melnavz
Need the operation manuel for my 22inch Gateway monitor can't change operating language
I have a smaller sized Gateway monitor than yours, but I'm sure the monitor buttons (on the front) perform the same functions on all sizes.
You should have eight control buttons on the front of the bezel (as listed from left to right): source, menu, down arrow, up arrow, left arrow, right arrow, auto/set, and on/off buttons.
Press the menu button, the first dialog screen that appears (at least on mine) is the brightness/contrast function. The screen will show the function to be changed, and a very small picture of what screen you have in view.
Once the first function is listed on the screen, press the down arrow to access the other screens (color, tracking and set-up), each having their own little picture indicating what screen you are looking at.
Brightness/contrast - picture of half light, half dark circle
color - RGB picture
tracking - two squares on top on one another slightly off center
set-up- hand pointing left
You want the set-up screen which shows a picture (I think) of a little hand pointing to the left. Once you are in the set-up screen, press the auto/set button and the first line will be highlighted (usually it is the language choice).
Once highlighted, press the right arrow button until your language name appears (i.e., English, Duetsch, Francais, Espanol Italiano, -there is no choice on mine for Japanese, etc.).
Press the menu button again and that should do it.
Feb 10, 2013 | Gateway HD2201 22" LCD Monitor
Samsung plasma 42" model HPR4252xlxaa only have picture in center of screne the rest is black or black mesh. sometimes the whole screne brightens up for 15 to 30 seconds with great picture then goes b
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 02, 2018 | Samsung HP-R4252 42 in. Plasma HDTV
Polaroid HD TV 32" Black square in the center of the screen,
Is your closed caption selected? I saw the same problem with my friend's Sansui HDTV.
Jan 18, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
I have black screen no video. First start up momentarily picture appearing than no picture only audio.
The backlight inverter board may have gone out, or power supply for the inverter is bad. Check the power supply first since it is easier to get to. Look for bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 12, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Black square on screen that covers half the picture appeared on my 42" sharp aquos tv.
sounds like you might have PIP turned one (picture in picture) .. if there is no input hooked up for the PIP . you will just get a black screen ... you should be able to move that PIP around and change its size .. indeed turn it off .. look for a menu item called PIP .. select PIP off ..
Nov 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Large black square blocks screen
Most likely it's the closed captioning has been turned on. From your post I assume you have the remote control and able to access the menus so try to turn off the closed captioning. I'll be notified if you post something new.
Nov 27, 2008 | Toshiba 32A33 32" TV
Black square
hmmm...the black square syndrome..sounds like the picture in picture settings are unhappy..check those, to see if maybe it's on some sort of timer, and accessing a non channel(which might explain the black square).
Feb 29, 2008 | Hitachi 57F500 57" Rear Projection...
Black box in center of the screen?
could it possible be a problem with closed caption setting....is this a square or rectangular box how big?
Feb 15, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 23HLV87 23 in. LCD Television Logo
195 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
