Question about Maytag Washing Machines
The washer stopped working during the spin cycle. And left about three inches of water at the bottom. and now it wont even turn on.
  • 38 Answers
You have a faulty lid switch.
Posted on Jul 23, 2008
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
The wash cycle works, but once it gets to the rinse/spin cycle, nothing happens. The washer is full of water and nothing is happenening, even when I try to make it work manually.
The pump is clogged. I take it this a front loader. Pull the bottom panel off (three screws on the bottom) You'll see the pump on the bottom right. Unscrew that clean out (It's going to get messy). You'll probable get a lot of stuff out of there, make sure there is nothing left INSIDE the pump. If the water can't drain the washer won't spin...good luck.
Oct 20, 2010 | Whirlpool Washing Machines
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
M9503 washer dryer not draining before dry cycle.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 22, 2009 | Hoover AAA140 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer moves during the spin cycle
Due to strong vibration during spinning definitely the machine will stop. All you have to do is to check your load if equally distributed from the tub. To eliminate the vibration and the movement of your washer you need to align the four legs of your washer using level tools. Just put the level on the top of the four sides (front side, left side, right side and backside) then make necessary adjustment if needed on the 4 leg of the washer. Also check the water level of the balancer and the mounting position from the top of the tub.
Jan 31, 2009 | Whirlpool LSR5132PQ Top Load Washer
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
