Recentley my tv just turned off. I heard a buzzing sound which happened the 1st time my bulb went out. So I ordered a new one. When the new one was put in it worked for 5 minutes then turned off and when I turned it back one I just heard buzzing noise around the bulb. Bad bulb or is something that starts the bulb up bad. This is a dlp tv model number wd-65731
  • 4,234 Answers
This could be a couple of things. Look at the cooling fan and be sure that it can spin freely. If it is stuck, the buzzing could be the motor trying to spin the fan. Other than that, the ballast could be failing as well. This is the part that "fires" the lamp. Examine the fan first and let mw know what happens.
Dan
Posted on Jul 23, 2008
Tv sound buzzing lamp
Contact any service technician.
Oct 09, 2013 | Mitsubishi WD-Y65 65" HDTV
Hi. I have a 2004 52' Flat screen projection TV. For the past couple months, we have turned on our TV and all we hear is sound, but no picture comes up. We thought the bulb was having problems. We ordered...
The buzzing is the ballast arc gap,normal sound. When the tv starts does the lamp start to come on. Can you see any light from the back? Sounds like bad ballast. Unfortunatly this part is no longer available. the light engine will have to be removed and sent to Toshiba to be rebuilt.
Nov 26, 2009 | Toshiba 52HM95 52" HDTV Projection...
No picture and buzzing sound on Sony XBR Wega
Is the bulb light flashing ? - Sony's bulb light is very accurate in telling you if the bulb is bad. The buzzing sound could be from the balist trying to strike the lamp. You also may want to open the lamp door and see if the bulb is shattered.
Aug 01, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
I had the black & white dots on my 46" HLS4676S..Replaced the DMD chip..Plugged it in and the indicator lights then said I had a bad bulb...Installed a new bulb and the same thing happened. Turns...
Make sure you have firmly seated the new Lamp. The next step is to go to the rear of the set and put your ear next to the Lamp Door while turning "ON" the tv with your tv remote.
You should hear a short buzzing sound. That is the Ballast "Exciter" firing up to light the Lamp. If you do not hear this buzzing then you probably have a bad Ballast. Ballast part# is BP47-00037A
Jul 17, 2009 | Samsung HLS4676S Television
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
Jun 08, 2008 | Toshiba 50HM66 52" Television
Sawing noise
Sounds like the same problem I encountered with my TV might be
ballast.
Dec 31, 2007 | RCA HD50LPW42 50" Rear Projection HDTV
No picture, just went off while watching tv
The pink lines in the set happened when the first time it blew out. It is called a burn in on the inside surface of the picture tubes. Not the fault of the TV repair guy. This is the fault of Toshiba. This set has known to have this happen and you should contact toshiba and request that they replace all three tubes for you at no cost. You should also stop using these repair guys who cannot fix a simple vertical problem. Find out who is authorized for Toshiba in your area and call them. They will know, or should know the problems that happens with this model number and take care of them once and for all. Good Luck
Nov 06, 2007 | Toshiba 51H84 51" Rear Projection...
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
