Warm air from the furnace hits extremely cold glass, it turns to condensation, which is what you're seeing. Does it have anything to do with the furnace? Yes & No. Depends on how warm you have it in the house. 70 and above would could cause it, because it's so cold the furnace has to run longer to keep up. Try tuning the thermostat down to about 65 to 67 degrees.
Also, the windows may be playing a role in all of this. Especially, if they are old, single pane windows.Or they are leaking air around the seams. Do you have storm windows and are the windows closed for the winter? Perhaps the house doesn't have enough insulation in the walls and attic. Are the soffit vents blocked by insulation? If you have a venta-ridge on the 'A' of your roof or exhaust vents on the roof blocked by snow? All of these vents are designed to move air in and out of the attic. All these thing need to be addressed to make the house more energy efficient. Which in turn will solve the problem of your seating window.
Also, if your furnace has an automatic humidifier, you may want to lower the humidity level a bit.
Hope this helps you understand what causes your sweating windows.
Rich
Hello, if you have a humidifier running along with your furnace than it is set to high and must be turned down. Usually this is what causes condensation to form on the windows due to a big temp differance and humididty between the indoor air and outside air.
Scientifically speacking, several factors add water to a window, cooking water for food to eat, the moisture will travel around the home and find it's way to a window.
Humidity in the home will cause moisture to develop on windows
Heat againts a cold surface will indeed create moisture on a window, when cold meets hot like in the atmosphere.
Thankyou for using fixya.com
i know this has nothing to do with the question you answered but i seen you comment on another person problem about the car i have and i wondered if you could help me out , i have a 2002 olds alero and when i drive it for awhile in the heat it will just kinda die when im at a stop sign or slowing down. but it will start back up. at night i can drive around for hours and ill never have this problem. So would you happen to have a soulution for me?
