Question about RCA 14F512T 14" TV
TV wont turn on
The tv will not turn on... does this model have a fuse link of some sort or some sort of surge protection? if so. where is it located?
More than likely your FPA lock is on and will need another RCA remote or order a remote for your tv in order to remove
Posted on Jul 29, 2008
Today my power went out for a split second and came back on I turn my TV back on it makes a high pitched whining noise and the screen wont turn on. Cant add picture but model number is MW30G71.
unplug your tv. let it sit for a good bit. 1/2 hour did your power just go out or did you have a power surge then no power. surges cause the grid to go down for a second too and that causes problems too. surge protectors are good for everything. also are you on cable? if so have the cable company check they're filters into the house may be an issue but check the tv after a half hour unplgged and then plug in and turn on normally? sometimes it needs a reset time period before the fuses inside will reset themselves.
Nov 17, 2015 | Televison & Video
Wont turn on
whille tv running after 5minutes
shotingdown
Nov 26, 2013 | Akai CF2791 27" TV
Hi, I have a Rheem water tankless heater and there was a storm lastnight so suddendly I have no hot water. What can It be?
1) All tankless water heaters require voltage to operate electronic sensors and circuit board.
This is true for gas and electric tankless.
2) Check that circuit breaker is not tripped. Push circuit breaker all the way one direction and then all the way back other direction.
3) There are fuses located inside the tankless unit, so check your manual for location of each fuse.
Manual is filled with useful maintenance and troubleshooting steps.
4) Before calling service technician, open following link for troubleshoot resources including manuals, Rheem on-line chat, and useful links for maintaining tankless water heater.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
5) If you had nearby lightning strike, I don't know if your tankless is protected from surge.
I recommend whole-house surge protector for tank and tankless water heater electronics, and household circuits. Surge protection is installed in main breaker box, and is replaced after each surge event. Separate protection needed for co-ax TV satellite, co-ax surge protection can be found on some ordinary power strips.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#surge
Apr 11, 2011 | Rheem Tankless Hot Water Heater...
I turned on my tv this morning and it started smoking and of course smelling like something inside was burning. We took off the back and can see nothing that looks burnt or melted but the tv still wont...
hi,
may be ur tvs lamp side have some problem. may be the lamp over heated and burned. just open its lamp cover ann check it.
also check its power supply input point(near fuse) there is an MOV (used for voltage surge protection) is burned or not. if there is any voltage surge it will get shorted and the fuse will blow off, protect the power supply for any further damage. check the fuse also. if found open then check the MOV. insert fuse only after replacing the MOV.
ok
Dec 22, 2010 | Samsung HL-S5087W DLP TV
HAD A POWER SURGE NOW MY TV WONT POWER ON
The tv power LED light now totally dead or power LED light indication flases?The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries website like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 11, 2010 | Sceptre X23BV-Naga 23 in. LCD TV
Tv does not turn on after a thunderstorm and several attempts at power returning to the home. The power went on briefly then shut off several times, now the television will not turn on. We had the tv...
Check the main fuse in the power supply, the TV also has small surge protection devices (MOVs) installed after the fuse, any surges the come along and big enough will cause the main AC fuse to blow. When you surge protector, EVERY connections must go through the surge protector, for example, the AC cord of the TV is connected to the surge protector, the cable connection did not go through the surge protection, the surge then can get to the TV through the cables.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 21, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv wont turn on
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
Feb 19, 2009 | Philips Magnavox 27MS343S 27" TV
My sylvania wont turn on.
What is the make and model for your unit? Which state are you located in?
Mar 16, 2008 | Sylvania 6842PE 42 in. HD-Ready Plasma...
RCA 14F512T 14" TV Logo
127 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
