Question about Philips Magnavox 20MS233S 20" TV
How to unlock the smartlock code
Can you please tell me how to unlock the smartlock i don't know how it got on there but it is blocking my channel, how do i reset or unblock the code.
  • Ryant Aug 02, 2008
    yes me too, I purchase used Philips Magnavox, but it apparently there is block system is on.. how to reset the parental control? can anyone help? thank you so much!
  • Anonymous Jan 26, 2009
    my magnavox tv has every channel blocked by a smart lock and i dont know what to do does anyone know how to override or disable it!!!!!
    HELP ME !!!!
4 Suggested Answers
TVtechmaniac
  • 140 Answers
SOURCE: smartlock code
1.Press MENU to show the on-screen menu. 2. Press VOL+ or VOL- to highlight SET. 3. Press CH+ or CH- to highlight PARENTAL CONTROL. 4. Press VOL+ or VOL- to display the SECRET CODE screen. 5. Press VOL+ (on the remote) and the CH+ button on the front of the TV at the same time. 6. Press the Number buttons to enter a four-digit code. The code will appear on the screen as you enter it. The code "0000" is the default of the TV. If you have not set up a code previously,then "0000" is the code.You cannot use "0000" after you set your own code (unless you reset the code to "0000"). 7. Press MENU to save the code.
Posted on Oct 10, 2007
I used the following that I found on a site that compiles v-chip reset solutions:
Philips and Magnavox:
Philips sets use a four digit code to control the v-chip. The override code
for Philip sets is 0711, although it may say "Incorrect code" the first time
to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To
use it hit the MENU key to get to the menus. Go up or down until you reach
AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow"
key on the remote. Enter the override code, and enter it a second time if it
says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right
arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to
MASTER DISABLE and press the "right arrow" key so that it says "MASTER
DISABLE ON". The v-chip is now reset.
Posted on Apr 03, 2008
salsaurbana
  • 56 Answers
SOURCE: Smartlock on Magnavox TV
Chek in the back of the tv if there is a tiny button, probalbly that you have to use a ball pen to hit it, that says "RESET". press and hold it for 10 seconds an release it.
Posted on Nov 23, 2008
Anyone know what the code is to get my tv unlocked?
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Jul 05, 2012 | Philips Magnavox 27MS343S 27" TV
Cant unlock tv because the code 319753 mute is no longer working
Hello
OK.
Aug 01, 2011 | Philips 20PT6441 20" TV
Hi my TV has a picture of a padlock and i cant unlock it tried to use remote it wont work it is a magnavox 29inch
hi,
For unlocking you tv you have to reset its v-chip. Do the following for the same.
ok
Apr 11, 2011 | Philips Magnavox 20MT133S 20" TV
I bought a used TV with an existing access code. I don't know the code and some channels are blocked. How do I disable the code? or reset it?
Hello
First disabel the lock and re-enter your own lock code. For this do the following.
OK.
Jan 10, 2011 | Philips Magnavox TS3260C 32" TV
Need code for tv remote to operate tv by the remote
Hello
You cannot change Parental
Control settings without
knowing the secret code. If
your code changes, someone
else has altered it and possibly
viewed blocked channels. Yet try the following procedure:-
Philips sets uses a four digit code to contro the V-Chip. The override code for Philips set is " 0711 "
OK.
Dec 28, 2010 | Philips Magnavox 27MS343S 27" TV
Tv is lock with smartlock
The Factory code number is 0 0 0 0 If the code has been changed, You can select to reset it using the Setup Code either under the channel blocking or setup code section.
Once there, Press 0 7 1 1
You will be given a message "INCORRECT ACCESS CODE" Press 0 7 1 1 on the remote again
Next, "enter your new access code" shows on screen.
Now you can enter a new 4 digit code. (write it down somewhere)
Feb 15, 2009 | Televison & Video
Nov 05, 2008 | Philips Magnavox TS3260C 32" TV
Smartlock code
Apr 03, 2008 | Televison & Video
Smartlock code
Oct 10, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 20MS233S 20" TV Logo
263 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
