Question about Vacuums
I have a canister with a beater bar which i love. I have sucked up a sock (or something) in the beater bar and it will not work. I can't get it open to check it out. We have misplaced the booklet that came with it.
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=820565
Generic problem for all Vacuums
Posted by DFundis on July 22, 2008
I have a canister with a beater bar which I love. I have sucked up a sock (or something) in the beater bar and it will not work. I can't get it open to check it out. We have misplaced the booklet that came with it.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best thing to do is to see if you can open the power mate or powerhead, the sock is jammed in there and blocking the path of the dust and dirt. There should be some screws on the bottom to release the bottom plate or the top cover will come off, it would be one or the other it probably is stick in the gooseneck the swivel neck portion of the vacuum and or the wands or hose. If you need further help look in the owner’s manual or contact your local vacuum cleaner dealer in your area or call Sears cust serv listed below. If you need an owner’s manual Sears or your manufacturer will provide one for you if you give them the brand name and model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 23, 2008
The "rug mode" (when you
pull out contents - gently off beater bar. Push reset button.
Sep 03, 2011 | Kenmore 25512/ 25513 Progressive Canister...
The vacuum is on and sucking--but the beater bar will not turn on. Its not that its not rotating, the motor sound from the head does not come on.
If it is anything like ours, it is the circuit board. Needs replacing and like everything else Miele, it is expensive. Wish I had gotten something else. Tired of throwing money away to fix our Miele!
Nov 06, 2009 | Miele S318 Bagged Canister Vacuum
I have a windtunnel 2 vacuum. It sucked up a cord that wrapped around the beater bar. Now the bar won't turn. There was no smoke or sign of something burning. The motor still runs and there is suction but...
Check the actual beater bar for movement. I have seen the plastic melting, and bearings seized under such circumstances. Also I am unsure by your question, but the motor that creates the vacuum (sucking) is different than the motor that spins your beater bar, so make sure that both motors are operating. (there is usually a small switch in the bottom that turns this motor off when the handle is in the upright position) Hope this helps
Oct 10, 2009 | Vacuums
Unit powers up but beater bar does not rotate
Have you checked the belt that drives the beater bar?
Oct 01, 2009 | Kenmore 22812 Bagged Canister Vacuum
Beater bar not moving. Is there a belt? My mom sucked up a sock and didn't know. So she kept vacumming and then smelled something rubbery burning. And then we found the sock and cleared it. Then the beater...
The belt is broken or badly stretched and needs to be replaced. Here is a link to download a manual.
Look for the "Download Manual" on the right side of page. Scroll down towards bottom of page and you'll see how to open it up to change the belt.
Hope this helps.
http://www.azmanual.com/manual/16335/eureka-4700a-maxima-upright-vacuum-manual/
Aug 24, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Dyson Animal
Happened to me too. there is a reset somewhere, i got mine working again. try the Dyson website, sorry
Mar 26, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
95 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
