Question about Dirt Devil Reaction Twin Cyclone Upright Vacuum
When the vaccum is running the motor gets hot & smells & is very noisy.
The vaccum motor seems to be running very hard upon startup & makes lots of noise & gets hot. What might the problem be? I have practically taken everthing apart & replaced the filter & got all of the hair etc. off the brush roll. I haven't looked at the motor just yet.
Any suggestions you might have would be greatly appreciated.
Thanks.
-Andy
  • LDL ENTER Aug 13, 2008
    The vaccum motor seems to be running very hard upon startup & makes lots of noise. We checked the belt, the hoes, the filtter and the brush roll... pretty much we took it apart the best that we could, but were unsuccessful in reaching the mottor.... where is the motor located and what parts do we need to take appart to reach it... we suspect that there must be something jamed in the motor area.
    Please help.
    President:
  • 1,673 Answers
Sounds like yu may have a clog, either in the inlet by the brush roll, or the hose. If the hose comes loose, see if there is suction there. If no suction then it is clogged. If suction, then the inlet maybe clogged.
Posted on Jul 27, 2008
After a few minutes, vaccum emits a burnt rubber smell. Checked the V-belt and it seems fine.
It might seem fine but the burnt rubber smell means that the belt is slipping. This causes friction between the belt and the motor spindle causing the spindle to get extremely hot which melts the inner surface of the drive belt.
Take the belt off and examine the inner side that loops over the brushbar and the motor spindle. You will find that there are sections where the belt has partially melted - they are usually smoother than the rest of the belt.
Belts don't need to break before they need replacing. They just need to lose some tension. This is what seems to have happened in your case and you should replace your belt.
Regards,
BElectric
Dec 17, 2010 | Vacuums
Bissell 3750-T Bagless Upright Vacuum motor is hot, noisy, and smells like it is burned out, but still working. Can I replace the motor?
There are threee filters inside this unit. Be sure all three are clean. You can't clean the Hepa filter. You can only replace it. You may even try pluging it in and running it (not while vacuuming the carpet) without the filters to see if it is clogged up anywhere. It's not uncommon to **** up an object that doesn't fit though the vaccum hose very well and for that item to cause hair etc to catch on it and plug that hose. Before you know it you have a big plug in that hose. The hose detaches easily. Look through it.
Feb 24, 2010 | Bissell 3750 Lift Off Bagless Upright...
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Motor slows down and makes burning smell
If the noise is coming from the canister motor, you probably have bad motor bushings. I had the same problem, replaced the motor and all was fine - only for one year. The problem is back and is due to the fact the motor is very high speed (to get good suction) and should be made with bearings, not bushings. I will not be repairing a second time as a $70 motor annually is a bit pricey, and yes it will get VERY hot. I will buy a new vacuum - not another Kenmore.
May 25, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
The motor seems to overheat and smell a bit like burning.runs noisily too.this only seems to have happened since I used the small turbo brush for the first time ever on the stairs.
Check that there is no build up of fluff or debris in the machine. If the motor is getting hot its cos its not getting enough air ... through obstruction... probably you have something like a screw etc thats touching moving parts and restricting flow. Dont run machine hot... allow to cool right down before switching on again.
sue
Aug 03, 2008 | Miele Vacuums
Burning smell
Unlock the sweeper brushes and take them out. on each end is a cup bearing and should be free of debris.
then check around and under the belt and likely there is debris wrapped around it.
the post is getting hot as your pulling too much of a load.
though if it continues the motor may have a bad set of motor brushes (inside the motor) or bad wiring (kinda unlikely).
Apr 01, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Hoover Wind Tunnel Problem
motor burnout. replace the motor or get a new vacuum
Dec 15, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Dirt Devil Reaction Twin Cyclone Upright Vacuum Logo
276 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
