Question about JVC AV-48WP30 48" Rear Projection Television
JVC AV-48WP30 Convergence Problem
I have a similar problem to the ones I'v seen posted on your site except in my case the green picture is quite "askew". I was able to successfully move the red and blue targets using the convergence set-up feature on my remote and align them. However the green targets were quite distant from the red and blue and very skewed on the screen. I have read about replacing the STK chips, but will this really fix my problem? I am thinking that perhaps the entire DCM needs to be replaced. I have found some priced at about $250. What do you think is the best action to take?
  • farbo Jul 23, 2008
    I'm comfortable using a soldering iron. Which resistors need to be replaced (name and value), and where do I find these to buy?
  • farbo Jul 25, 2008
    I replaced the STK's but the problem is still there. Where can I purchase the necessary resistors and what kind (value) are they?
  • 2,336 Answers
If you know how to solder, I would suggest to just replace the STK ICs and some of the low value resistors. If you do not how to solder replacing the entire board is the way to to get the TV fix. You might still need to adjust the convergence after the board replacement.
Let me know if you need further assistance.
Posted on Jul 22, 2008
  • 1 more comment
  • Jaime Hernandez Jul 23, 2008
    You can buy the parts from this website along with the resistors. You can use the STK392-150 instead of the STK392-110, since the STK392-150 can handle more current.
    Make sure that you apply thermal compound to the ICs before installation to ease the heat transfer to the heatsink.
    The location of the resistors are R842, R846, R862, R850 and R854. Use a ohmmeter to check their values less than 2 ohms.
  • Jaime Hernandez Jul 25, 2008
    Have you measure the low value resistors?
    The picture below will show you the resistor location as well their value. Check any resistor that is below 3 ohms as well the 150 ohms.
    Click here to find the resistors you need.
    Good Luck.
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 problem starting up
The old video card has seen better days, methinks. All those symptoms lead one to conclude it needs a 'substitute' to enter the field, or call a long TV time out(too much pro and super bowl isms, eh?)..
Are you planning on doing this yourself?
Feb 11, 2008 | JVC AV-48WP30 48" Rear Projection...
Have a JVC AV-48WP30 rear projection tv set and the green seems to be out of place. the green image is lower than the others and is in a wave shape on top of screen and bottom.When I adjust the convergence...
Your convergence IC's are bad. If your not doing the work it will probably cost in the neighbor hood of $250.00 for a service company to do. Not a major repair.
Nov 03, 2009 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 foggy image
Check convergence adjust screen after picture distorts.
Description sounds like shading from a defective convergence circuit. If you replaced STK392-110 with 150, then re-install new 110's, or new 150's and re-design the circuit and change low-ohm resistor values to compensate for different IC's. It is not the same as a brighter light bulb.
See if the picture is in the CONVERGENCE GALLERY
easyab
Oct 18, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV 48WP30 projection tv bleeding problem
You need two STK392-110 Convergence ICs. You can get repalcements at the following link, and they will provide free instalation instructions with picture so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 24, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP34
The convergence ICs need to be replaced. I can post a link where to get replacement ICs along with free step by step instructions so you can do the repair yourself. Its an easy ,common repair , however a shop will be around 300 to 400
Mar 28, 2008 | JVC AV-48WP30 48" Rear Projection...
Jvc av-48wp30 convergence problem
1. if the 1.5 ohm resistor was open, then you may have fried your new convergence ic's. Sorry
2. bettween a 1.5 - 1.9 ohm resistor will work
3. press sleep button, set to 30
hold down video status button and press display on remote
select convergence from the new menu and hit OK.
Do fix the convergence before you try to align the convergence or it will look horrible after you get the circuit fixed and will be harder to align.
The white button is there because the DCU (digital convergence unit) can be erased by holding that button and turning the set on.
I WOULD NOT RECOMEND THAT AT ALL!!!!!!!!!!!
Hope this Helps.
Mar 16, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48 in. convergence
Imagine 2,4,6,8 like a joystick. Press 2 to move the spot to the left, 4 to the right, 8 down etc. To change the color press select. If is not moving you got hardware malfunction.
Dec 07, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP74 48 in.
The convergence circuit needs repaired. I did the same job yesterday on this model. I not only replaced the convergence ICs, but, I had to replace a couple of resistors and a coil. The convergence alignment was minor after that.
Jan 22, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
94 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
