Question about Garmin GPS
GPSMap 196 latest firmware. will not turn on when power button pressed if running on batteries. It will turn on if connected to 12 Volt DC car lighter power. It turns off immediately the ignition is turned off, i.e. no messages about "will turn of in so many seconds if no key pressed."
Duncan
  • 218 Answers
SOURCE: JVC KD-G351 question
It sounds like your stereo is working properly. I've never seen a car stereo that was wired properly that you could turn on and listen to while the car was off with the key removed from the ignition switch. You would have to move the ignition switch to the accessory position in order to get the stereo to work. Hope this helps. Good luck. Mike D.
Posted on Aug 21, 2008
  • 5 Answers
SOURCE: Key wont turn to Ignition point
you need to buy a new ignition tumbler
Posted on Dec 14, 2008
  • 3 Answers
SOURCE: Tom Tom Go 710 - Won't turn on
not sure but try an other device on the car plug to see if it works??????????? could be the plug.
Posted on Dec 21, 2008
SOURCE: garmin nuvi does turn on when connected to power in car
Hi
I had the same problem. My Nuvi 350 did not power up for a couple of days. I suspected moisture to be the culprit. So I took my wife's hair dryer and blew hot air(in the intermediate setting) into the SD card slot in the GPS for a couple of minutes. Take care not to overheat the GPS or Screen.
Pronto my GPS powered up without any issues.
Hope this helps
Posted on Feb 12, 2009
mcl_dude
  • 30 Answers
SOURCE: Recharging the Vector Start-It compact elite Jump Starter 12 volt
yeah from what im to understand... you charge it overnight, and yes another way to use it (and possibly better way) is connecting to the battery directly..... it should work on your van fine i think, its worth a shot, hope this helps :)
Posted on Mar 11, 2009
I have a 6000 watt allpower generator that the 12 volt breaker poped out reset it still no power replaced the avr ran for about 5 seconds then poped the 12 volt breaker again what could it be
Barry,
The 12v system does not go through the AVR. It most likely is the Battery Charging Rectifier has failed. This controls the voltage from the 12v feed from the alternator and charges the battery.
1) Follow the wiring from the 12v socket/connectors until you come to a Block rectifier. It will be held on by a bolt in the center and have 4 wires connected to it. If you look at the pins you will see one is seated at a different angle to the others. Test the feed to this pin, you should get a result of between 12 Volts DC to 16 Volt DC.
If you are not getting these results then the Block rectifier has blown and will need replacing. http://www.generatorguru.com/rectifier-98406168/
2) If all is testing fine above, then you will need to test the Battery Charging Rectifier as you have an Electric Start and Battery on your unit. This is a metal block located on the back of the engine, next to the starter motor and it has fins running across it. ( to see an example of this part look up your generator on this page http://www.generatorguru.com/all-power/) Again this should be giving you between 12 Volts DC to 16 Volt DC.
3) Next,check the voltage going into the Battery Charging Rectifier from the alternator. You should get between 12 Volts DC to 16 Volt DC.
For replacement parts please see our web page. You will need the full model number to do this.:
Dec 06, 2016 | Allpower Electrical Supplies
Can these be battery operated? If so can this be done.
Yes, you go through a converter.Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DC AC Power Inverters 12 Volt DC to AC Inverter
12 Volt DC To 110 Volt AC Power Inverter for Auto RV and Boat compatible...
Mar 12, 2016 | Mediasonic HomeWorX HW-150PVR ATSC Digital...
It does not seem to be charging the batteries. 12 volt lights work good for about 2 days then go dim until I put a charger on the batteries and bring them back into working order. The battery connect...
The Parallax 7155 converter should not require battery support for any 12 volt load amperage that is less than the maximum amperage capacity of the converter. A standard RV incandescent 12 volt lamp draws about 1.5 amperes for each bulb. With the battery disconnected and other 12 volt loads off, turn on lamps (not fixtures) and calculate the number of bulbs which can be turned on. If you run out of lamps, turn on vent fans etc. The idea here is to try to get to 55 amperes of DC load if possible without going over 55 amperes. At a sustained DC load of about 25-30 amperes or higher, the fans should cycle on continuously after about 5 -10 minutes. Lamp brightness should be normal and the measured voltage from the converter should be above 13 volts if under 55 amps of DC load. If the voltage drops with only a few lamps on, a converter issue would be likely.
Diagnostic tests an RV technician should make would be to:
1. Disconnect the battery system.
2. With the converter system powered on, measure the DC amperage with a DC ammeter capable of reading at least 60 amperes DC from the blue lead at the DC fuse panel terminal VCC.
3. Measure the DC voltage at terminal VCC and DC ground.
4. Record both readings.
At any DC load amperage less than 55 amps, the voltage should be above 13.0-13.2 volts DC. This method should take out all guesswork and confirm a DC converter section issue or not.
Nov 04, 2013 | Parallax Power Supply Parallax 7100 Series...
How can i power my cpap sleep machine while camping
I bought a 12 volt DC power supply mechanism from cpap.com that can plug into the cigarette lighter of a car or truck, or be connected to an external 12 volt battery. Car batteries can only be drained and re-charged a few times, without damaging the battery. But marine batteries are available, used by fishermen to run electric trolling motors on their boats, that can be recharged indefinitely. They are heavy.
Apr 19, 2013 | Office Equipment & Supplies
I have small portable generator with 220 vac in the philippines and a 12amp 12 v ac to dc converter. can i connect my 1000 w inverter to produce 120 vac becouse i dont have the batteries yet to run the...
no these are made to run off a batteries the 12 volt supplied from the gen is for charging batteries only and if the engine for starting the gen set has a battery their usual to small to run then their made for car style batterers.
hope this helps
Aug 14, 2010 | Vector 2000w Power Inverter
Starter
could be the wires need cleaning or new ends.or low battery power. check battery for 12 or 13 volts.if good on volts disconnect starter wire(dissconnect battery first) then hook up dc volt meter to starter hot wire and a ground at the battery.watch volt meter when u press the start button,do you still read more than 12 volts. if not replace solenoid.
Mar 25, 2010 | 1997 Honda VTR 1000 F Firestorm
Can i run my minn kota 30 trolling off my power box
Are you referring to an inverter by a "power box"? That term doesn't really describe the device. I'm going to assume it's an inverter you're talking about, a device that takes DC and turns it into AC. I'm not sure about that, but you should be able to plug a converter (turns AC into DC) of the right voltage, 12 to 14 volts DC into a generator on the boat and run it. I'm assuming the trolling motor runs off 12 volts DC and NOT gasoline. Be sure to check that before doing anything. Most do run off a large car or RV battery. Lead Acid Batteries for boats and cars produce 12.7 volts DC if they are in good shape and should have six cells (about 2volts per cell). 6 volt batteries are somewhat rare these days and have 3 two volt cells. Two of them in series will also power it.
Thanks for asking that question ... I like to fish also.
Lynn
Mar 20, 2010 | Black & Decker PI400AB Power Inverter
How do i tell when the inverter is charged?
Question does not seem to match this inverters capability.
INFO:
This Power Inverter converts vehicle’s 12-volt DC power into household 115-volt AC power. AC and USB outlets power and/or recharge personal electronics.
We have owned one of these Power inverters for over a year now and have run a great deal with it, from TV to drill press PC and any thing that was small and that could run from my car. Very nice product.
SET UP: Connect wires. ensure correct polarity, push button on top. Plug in 110 volt appliance.
Hope this tip was of some use.
R/
David
Feb 12, 2010 | Black & Decker Power Inverter PI400AB
Garmin nuvi 5000 wont turn on. I can plug up the usb up to the computer and the screen shows garmin logo with a gps connected to a computer like its charging. But when i press the power button weather it...
Your nuvi 5000 does NOT have a internal battery and that means that you cannot operate it unless it is connected to a 12 volt power source. Connecting it to your computer via USB allows you to install map updates, check for firmware updates, etc, but you will not be able to use it as a gps while it is connected to the computer. There is nothing wrong with your gps.
To use your gps in the home you need to purchase a 12 volt adapter, there are several types, plug the adapter into your wall outlet and connect your gps to it. If you can sit near a window it will help in picking up the satellite signal. Just keep in mind that you cannot connect the 12 volt power supply and use the usb cable at the same time. Enjoy your gps.
Jun 11, 2009 | Garmin nuviĀ® 5000 Car GPS Receiver
1994 Buick Century, V6 - Total loss of electrical power
ck your batterie it should be reading 12 volt dc then your batterie terminals ck for cracks acide build up and corrosions ck the ground cable for proper connection to the engine first then to the engine. if your batterie is not at 12 volt dc then you probabily have an alternator problem have it ck from a nearest parts store nicoas
Dec 13, 2008 | 1994 Buick Century
GPS Logo
46 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
