Question about Durabrand PDV-705 Portable DVD Player
My Portable DVD Player wont play
It says loading, the disk is spinning, then stops. The DVD is brand new, just baught it. Please help me out with this problem. My eamail address is:
atlhjsahrrahaslh@yahoo.com
Thanks Scott
    Problem Solver:
  • 15 Answers
You may have a dirty dvd, these players are very sensitive. try cleaning it or better yet put in a new one. if that doesn't fix it, i'd say return it for another. good luck.
Posted on Jul 24, 2008
I have a digital labs model K715 dvd player. when i put a disc in, it spins, screen say its loading but will spin, stop, spin and stop again. Wont play the disc.
Try doing the following...
Making sure the "line select" has been switched from "in" instead of "out". Once you switch it back to "out", the player should work normally.
Mar 05, 2011 | Insignia NS-PDVD8 Portable DVD Player
I have a Polaroid pdm-08228bd that whenever we put
when you open the cover for the DVD you will see the laser ..its a small lens like device mounted on a spring like assembly .. you can manually clean that laser with a soft paper towell soaked in eyeglass lens cleaning solution .. dont spray the solution on the laser directly .. make sure the spindle spins freely in the center where the disk mounts ... when you close the lid and turn power on you should be able to hear the disk spin .. if you can hear it spin and hear some clicking but still wont play then you likely have a worn out laser .. unfortunately the cost of installing a new laser is often greater than the cost of a new DVD player ...
here are a few models that might be worth looking at ..
http://www.consumersearch.com/portable-dvd-players?gclid=CITHuImPjaICFchD5godvmnzUw&ef_id=1953:3:s_241d3be5bdd1ae954a703c1c03b3e8bb_3674119072:TAxys0NIYWYAAGzz04MAAATA:20100607041651
Jun 07, 2010 | Polaroid PDM-0723 Portable DVD Player
Acer aspire 2930 DVD player only opens some dvds
Try Media player classic under k-lite codec pack. Then open video files on the dvd. If it doesn't help try another codec player. If nothing helps could it be that dvd player is not capable of multilayer dvd reading.
Apr 10, 2009 | Acer Aspire 2930-4661 Notebook
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Durabrand portable dvd player motor spin but disk not playing
I have the same problem, the this dvd player i use one time
Nov 17, 2008 | Durabrand DUR7 Portable DVD Player
Dratted Coby TF-DVD7100 Portable DVD player not working!
Its defective. Coby doesn't repair the units. The lense is off balance which is causing the laser to not read the dvd/cd.
Apr 17, 2008 | Coby TF-DVD7100 Portable DVD Player
Dvd
ribbon cable issue found with this device. look inside at the white ribbon cable. The cable likes to bunch in bewtween the spinning hub and the eye assembly, after time it may even develope a rub spot that will shut you down for good. If the cable is bunched up, try pushing it back into the bottom of the device and try again.
Nov 15, 2007 | Durabrand PDV-705 Portable DVD Player
INSIGNIA IS-PD040922
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Nov 27, 2006 | Insignia IS-PDO40922 Portable DVD Player
Durabrand PDV-705 Portable DVD Player Logo
59 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
