Question about Protron Televison & Video
Flat screen tv
I can't activate the TV set. The red light is on and the power button on the remote and the top controls will not turn the set on. What's wrong?
  • sstone338 Jul 23, 2008
    The flat screen tv is working fine after I tried what the "guru" suggested. Thanks a lot!
  • Protron Master
  • 19,396 Answers
First try unplugging power cord for ten minutes or so
Posted on Jul 22, 2008
My sony tv wont turn on
There is a powerbutton on my sony TV - no amount of pressing the remote will activate the telly unless I forstpop the power button on the top. Once it has been initiated teh remotes work fine.
ALSO check the remote is working by activating a digital camera - can even be a smartphone - point the remote at the lens and you should see a flashing light on the camera screen, if not, check the batteries etc (try another remote for something you know is working to compare the result)
If all that fails, it may well be the TV that's broken.
Jan 03, 2015 | Sony Televison & Video
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
Aug 09, 2008 | Televison & Video
Remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
Sky remote code fo LCD LE40A456 TV
3. Press tv again
Samsung Code: 0060
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Remote code needed (sky+) to sync with Sony bravia kdl32v2000
3. Press tv again
Sony Code: 0000
Jan 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Pairing Sky+ Remote with Panasonic Viera remote
3. Press tv again
Dec 29, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
Sky remote tune to samsung
3. Press tv again
Samsung Code: 0060
Aug 13, 2008 | Samsung WS32Z308P 32" TV
32PFL5232D/37
The code is 0081 and this is how you do it.
'4 digit' or 'Brand Set' method
1. Turn on your TV.
2. Press TV on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press TV on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press TV guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide, you must now set the TV Guide function as follows:
8. Press TV on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
7. Press tv guide .
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
Televison & Video Logo
50 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
