Question about Zenith R56W36 56" Rear Projection Television
Convergence IC What is the difference between STK392-120 and STK392-570?
What is convergence IC
It's the large integrated circuit (IC) that controls and coordinates all the settings to do with the various convergence controls in a projection TV. It may also store various convergence memories required to deal with different type of signal.
Sep 08, 2014 | Televison & Video
Colored lines at top and bottom when tv comes on and seeing double vision in different colors at all times
If your tv is not a DLP the problem is in the convergence, try to adjust it using your original remote control go to the setting menu then to the convergence section. Adjust the red and blue convergence. you should move the red and the blue in up, down and left, right if this color does not move far enough your convergence IC is already defective. Replacing this convergence IC will solve the problem. In locating this convergence IC you should remove the back cover of your unit but be sure to unplug it before doing this. This convergence IC is attached to a large aluminum plate, it is the heat sink, and it has a marking of stk- ### followed by numbers. You can try to pull it out using a soldering iron and soldering pump but be careful you may damage the board and cause much problem to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards.
Aug 28, 2011 | RCA Televison & Video
The color is messed up. the color is all different colors like red,green and blue.
Your convergence is out of whack.
This can be caused by a failed convergence IC - or can be adjusted using the Convergence settings in the main menu.
May 15, 2011 | Toshiba 55H70 55" Rear Projection...
Convergence problem
Usually what happens is that the convergence IC goes bad or the fuse going to the convergence ic goes bad. Pico fuses they are called sometimes open up. You may want to open it up and pull the board out and check the solder connections on the convergence IC. Sometimes these get fractured or cold soldered and aren't making connection to the PC board.
Let me know if you feel comfortable with pulling TV chassis out or pulling the board that has the convergence IC on it out. Then you can resolder convergence IC OR replace it.First thing i would do is check to make sure there is between 22vdc and 25vdc on the fuse or the convergence IC. Let me know if this helps out any.... Sincerely HDTV GURU JAY
Mar 17, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
Panasonic pt61hx41e convergence part number
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Dec 06, 2009 | Panasonic PT-51HX41 51" Rear Projection...
I have a Toshiba rear projection TV model # 50H71 for about a month the tv would randomly pop off (lose sound and picture) for about 45 seconds and then come back on now th picture is reduced in size by...
Good Day,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number
23905094 (STK392-110) using the revised “T” version IC Part Number
23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
Thanks for choosing FixYA, Big Irish
Nov 22, 2009 | Toshiba TZ50V51 50" Rear Projection...
52" rca hd proj. tv model # d52w23
Your symptom sounds like a damaged convergence IC, whick you have found to be true.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
You will also want to replace the white heat sink2.gif compound that is on the heat sink2.gif, just scrape it off, then clean the surface with alcohol. Then apply a thin coating of fresh heat sink compound, if you do not do this important step the new IC's will not last long as the old compound will act as an insulator to the heat transfer.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
Their site is http://www.andrewselectronics.com/welcome.aspx
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
Sep 04, 2009 | RCA R52WM24 52" HDTV Projection Television
The red convergence cannot be corrected
There are two ic that should be replaced in convergence. It is like doing your breaks on your car you should do both sides. the parts are only 30. dollars.there are differant kinds for each model
stk 392-150 or stk392-040 so on the part you need will be on the convergence .make sure you check the resistor around convergence ics if they are burned you have to replace them to.
a tv shop charges around 300.00 to fix this repair
good luck
thanks Doctor video leadingedegeelectronics
Apr 28, 2008 | Samsung HCN653W 65" Rear Projection...
No Picture after it's been on a while. Audio OK.
ok you have a vert sweep problem and yes its probably connected to in a way to the "tap and fix" problem! Seems to be n intermittant connection on the vertical out put Ic or maybe even on the rgb convergence ic?? The total loss of sweep though tells me that theres two differant problems! Maybe and intemittant connection on the vert output Ic as well as bad connections on the convergence ic??.
Apr 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Zenith R56W36 56" Rear Projection Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
