Question about Canon imageCLASS MF8170C All-In-One Laser Printer
Line stays busy
When the fax is plugged in and connected, the phone line stays busy. We can unplug and it is no longer busy. Can't find manual!
Thanks!
  • 148 Answers
Can not get a dial tone. Phone appears to be off the hook. How do I trouble shoot it?
Unplug the phone line from the fax machine. Wait at least 1 minute then call the phone number that goes to the fax machine from another line such as a cell phone. Make sure you get a ring and not a busy signal. If you get a ring then hang up the phone. Plug in the fax machine again and call the fax number again. If you get a busy signal then either your phone if off the hook, the switch that is actuated when the phone is placed in the cradle is bad or your modem in the fax machine itself has gone bad. Another thing to try is unplug the fax machines power cord for 30 seconds then plug it back in. I have seen the modems get "locked up" and keep the phone line open. Unplugging will sometimes reset this and get it working again.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
We cannot receive faxes. Gives a busy signal.
Unplug the phone line from the machine. Wait a few minutes then try calling your fax number from a phone while leaving the phone line disconnected from the machine. If it rings fine from the phone, then re-install the phone line to the fax machine. Try making the call again. If you now get a busy signal then the modem in your fax machine has gone bad and is holding the line open. Make sure when installing the phone line you are placing the cord into the "line" port on the machine and not the phone port.
Good Luck and thank you for using Fixya.
Mar 18, 2010 | HP LaserJet 3050 All-In-One Printer
Error code 634
Check your phone line by plugging a regular phone in.
Feb 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Problems with faxing
Plug the phone cord into the LINE port
Nov 25, 2008 | Canon Laser Class 810 Plain Paper Fax
Fax line stays busy continously...
Are there any other phones that use that line? If you have a phone attached to the fax machine, is the reciever in the holster all the way?
Jul 06, 2008 | Canon FAXPHONE L80 Laser
Vista Home new computer causing busy signal on home phone
In the modem there are two link one for the phone and other for the line . In the line link you have to connect the direct phone line and phone link you have get the extent cable, link it and connect it to the phone . try it and porb comes inform to fixya.com
May 12, 2008 | Dell Dimension 3000 PC Desktop
Fax problem
unplug the fax from the phone line. call it from you cell.if you hear your phones ringing in the house, plug the fax machine back into the jack. [you should still be on your cell phone] if the line goes dead or stops ringing, there is a short with the fax machine or wire to the jack.if you hear a busy signal without the fax plugged in, unplug everything you have plugged into phone jacks thruout the house. call your # again.if you hear ringing on your cell phone, plug everything back in one at a time.[again while still on your cell phone] if it was one of the phones plugged into a jack, when you plug the shorted phone back into the jack, the line will go dead again. that phone or cord is the problem.
if still rings busy when everything is unplugged, then call your phone company. it can be an inside wire or jack problem, or the problem is outside your home.
hope this helps
wg
Feb 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Can't receive faxes
Something is causing the fax machine to "trip" to busy. There is some type of short occuring either in the fax machine or the physical phone line itself. Unplug the fax, plug in a regular single line telephone. Call the fax number from another telephone. If the phone rings and you can talk to the other party, the problem is in your fax machine. If the call still is busy, the problem is in your wiring, either in your office or the phone company network.
Feb 01, 2008 | Canon FAXPHONE L80 Laser
Gets busy signal
You may simply have a bad phone line from the machine to the wall jack. If the connection is getting flakey it will cause it not to connect.
You could have a sticking relay on the fax modem circuit board.
Also you could just need to reset the machine via the manufacturers directions on how to clear the memory or reset the machine to defaults.
Another question is , do you have any other pieces of equipment on the phone line with the fax? Such as a credit card machine or other device that may be causing the problem. If you have more than one item on the phone line, try plugging only the fax machine into that line and see if that works.
Is there an extension phone built into the machine also? Make sure its not causing a problem either.
That problem has a multitude of issues.
You could also have a phone line problem. If your line voltage is low, line current low or you have alot of DB loss, it can cause that issue.
Sorry I can't narrow it down to one specific issue, but that one has lots of possibilities.
Nov 19, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Still a problem? Can you be more specific?
Jan 29, 2007 | Canon FAXPHONE L80 Laser
Canon imageCLASS MF8170C All-In-One Laser Printer Logo
83 people viewed this question
old marine
old marine
