Question about Maytag MSD2456G Side by Side Refrigerator
Refrigerator not cold
My freezer is fine, frig is not getting cold. It is 8 years old, coils, compressor are clean, had the defrost board replaced 5 years ago, seems like the same problem, what do you think
  • 1 more comment
  • midwesthellb Jul 22, 2008
    Thank you , is that hard to replace and do you know where it might be located? Thanx again
  • Anonymous Jul 25, 2008
    We have the same problem. How expensive is the defrost controller to replace. Besides the ice maker has never worked correctly
  • thewinns156 Nov 29, 2008
    I have the same problem. The fridge is not getting cold now and the freezer is not as cold.
    Habit-Forming:
  • 41 Answers
Very usual issue - defected defrost control unit - replace it and keep warranty paperwork from part supplier. :))
Posted on Jul 22, 2008
Why is freezer/Frig at 51/59 degrees with both fans running?
Good Morning Friend,
I understand your Frigidaire refrigerator, model# FRT18G6JB6, is not cooling well. I also see that you have checked the gaskets, cleaned the condenser coil, and manually defrosted your refrigerator. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why it is not cooling. Hope this is helpful,
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Refrigerators
I have a side by side whirlpool frig-freezer , I have had it for about 8 years and it defrosted complet and will not get cold. i cleaned out the coils with the vac, and cleaned everything out of both and...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 15, 2010 | Refrigerators
We have a 8 year old Maytag Side by side model MZD2766GEW and the fidge side doesn't stay cold, just cool. The freezer works fine and there isn't any frost. Any idea what we need to do? Thank you, Greg
For those who had the control board replaced or are experiencing the frig side warming while the freezer side continues freezing; The problem may (still) be a faulty control board. I fixed the issue by replacing a $1.00 capacitor on the board. I'm not a techy and it wasn't too difficult to solder. More info on what to do here; DIY Chatroom
In the mean time, there is ice forming behind the back panel in the lower section of the freezer. This blocks airflow to the frig side.
I use a pump pressure garden sprayer with hot water to defrost the coils. Gets the job done in 20 minutes and I don't have to worry about defrosting items in the freezer.
Jul 17, 2009 | Maytag MZD2766GES Side by Side...
Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
My KitchenAid KBRS22K bottom mount refrigerator is eight years old. Was working fine, but now the refrigerator does not cool, but the freezer stays cold. The fan seems to work and the coils have been...
the problem here is the defrost element is not coming on, the problem is the control board in the fresh food compartment is defective and not telling the element to defrost. Therefore your cooling coils are impacted with ice which keeps freezer cold, and sensor in freezer says everything is ok and therefore sends nothing to refrigerator. Replace the defrost control board, Thaw out the cooling coils in freezer, and your back in business
May 19, 2009 | KitchenAid KBRP20EMSS Bottom Freezer...
Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Mar 23, 2009 | Avanti FF1101W Top Freezer Refrigerator
Evaporator coils iceing over; warminhg on frig side of model 106....
As I said; the fan and compressor run fine but I cannot find the defrost timer. Is it integrated into the control board.
Thanks
Jul 27, 2008 | Kenmore 50522 / 50524 Side by Side...
Freezer cold but not frig. section
Switch off frig and let it completely defrost.
Jun 27, 2008 | Maytag MTF2155GRQ Top Freezer Refrigerator
Whirlpool Refrigerator not cooling properly
I would try replacing the defrost timer and cleaning the condenser fins.
Apr 19, 2017 | Whirlpool ET1FHTXM Top Freezer...
Maytag MSD2456G Side by Side Refrigerator Logo
255 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
