Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Help with washer
Washer just stops washing and does not start again unless I hit the top. Sometimes that doesn't even work. Could the timer be going out? I have had the washer since 2000 and have never had any trouble. # on the lid is LSQ8543J
  • 481 Answers
Yes it could be the timer, next time it happens jiggle the timer knob and see if does anything, if it does then you know it is the timer. if it doesn't then it may be something loose in the control panel like the wire harness on the timer may not be getting good contact.
Posted on Jul 22, 2008
I have whirlpool ultimate care II and sometimes it stops working during washing, sometimes it wont start. now the only way it sometimes starts is when I switch the load size a few times, and then it will...
It seems a lot like a timer issue. Advice to you is the next time it stops just tap or knudge the timer knob, if it starts up then you just found your problem.
Jun 11, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
Sep 19, 2008 | Kenmore Elite 45986 Front Load Washer
GE adora WHDRE526EWW when started it begins to fill then stops filling and have to restart sometimes three to four times help!!!.
I wish I had a solution, I have the same issue. My WHDRE526EWW Top Load washer stops intermittently sometimes while filling up, sometimes while rinsing, sometimes while washing and sometimes while spinning. I just have to guess when it's going to stop and check on each load frequently to restart it when it stops. Sometimes I can't even get it to start spinning again and I will have to unplug it and plug it back in and then it will spin. Hope someone can help!
Jan 05, 2010 | General Electric WHDRE526EWW Top Load...
Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Does not drain all of water out unless you raise the lid during spin cycle
This is sometimes the coupler, sometimes timer has shorted out.
Sep 22, 2008 | Kenmore 23822 Top Load Washer
My Maytag Washer
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
