Everything seems normal until i go to sign in and then the error code pops up and says try again or cancel or quit and i have no idea what to do.
  • 148 Answers
What error code?
Posted on Jul 22, 2008
Error message on Whirlpool Range Oven Model GFE461LVS Feature Not Available
The Feature not available message indicates that the range's internal computer (electronic control) has found a problem with the range. You need to access the diagnostic program to determine the fault and try to reset it. Press Cancel, Cancel (a second time) and then Start. You should see Test On. Then press Temp > Time > + . Press + again to move through the various test and information sections. Eventually you should get a list of Faults (F followed by a number or F number E number). Record these. After you press + again, the diagnostic program should enter an "Auto Test". Press Cancel to exit the test. Then press Start Time to clear the fault codes. Then try to use your oven.
Some faults mean that the oven can't be used until you fix the problem. These can be problems with the ERC (electronic range control), high temperature limit sensor, or wiring harness. Some of the parts for your range are available here: http://www.appliancepartspros.com/search.aspx?model=gfe461lvs . Without the error code, I can't pin down your issue. So please add a comment with that information after you try the diagnostic.
If your range is under warranty, contact Whirlpool for a service call.
I hope this helps.
May 10, 2016 | Whirlpool GFE461LV Electric Range
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
I am having problems with my PS D7360. Error code 0xc18a0306 keeps coming up. I have tried the pineworks suggestion but it did not work. The printer has been sitting for a while.
Found this here it's worth a shot. http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/Ink-System-Failure-C6180-error-0xc18a0306/td-p/161866
1. press * and # to enter a secret support menu.
2. Enter code 123
3. Press Right button until "System Config Menu". Press OK.
4. Hardware Failure Status. Press OK
5. Press OK to Clear.
6. Cancel
7. Press Right button to Ink Initialization Status. Press OK
8. Cancel and Cancel to the secret support main menu.
9. Press Right button until "Print Tests Menu". Press OK.
10. Nozzle Test. Press OK
11. Wait until the print test is finish.
12. Press Cancel and Candel until the error 0×00000000 appear and then power off.
13. Power On again. The error disappear.
May 28, 2011 | HP Photosmart D7360 All-In-One InkJet...
I have the test displayed and it dosent matter
There have been 3 versions of Demo Mode used on these appliances.
Version 1(Production to- Date code 39 March 2005)
To Activate
1. From the Default screen of a programme, after switching the appliance on press both Start/Cancel and On/Off buttons together until d On appears in display.
2. Press the Start/Cancel button only and test appears in the screen (Temp & Spin symbols also appear)
To Deactivate
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Version 2 ( during Date Code 39 March 2005- to Date Code 42 June 2005)
To Activate
1. Same method as version 1.
To Deactivate
1. Simply press the Cancel button and the appliance returns to default.
Version 3 (During Date Code 43 June 2005 - to date )
To Activate
1. Press On/Off and Start/Cancel together with the top left option button until d On appears.
To Deactivate
1. Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
Feb 24, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error msg. 5c10
cancel the printjob. Shut down and uplug printer and wait at least 10 minutes before starting the printer up again.
Hope this will solve your problem.
Sep 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Unable to cancel cycle and restart machine
Instead of hitting cancel twice, only press once,. You should hear the washer unlock. Then try to start again. If that doesn't work, try unplugging the washer in mid cycle. Are you getting and codes popping up?
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
I am getting a message Zip error.... this is not a valid zip code please try again when i click ok or cancel it comes to another window which shows " please enter the zip code that you would like to...
Is this on Vista sidebar or any tool bar on IE. Kindly disable the Weather bug where ever you see it on ur pC by doing right click you will get an option to disable it
Feb 03, 2009 | Computers & Internet
Kenmore Elite HE5t Power and Errors
try hitting pause/cancel twice to clear the codes
May 17, 2008 | Kenmore Elite 45986 Front Load Washer
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
