Question about HP Color LaserJet 2600n Printer
Cleaning? i have used the service cleaning mode and still i have faint but really visable black verticle lines running down the center of the page
Replace your transfer belt!
Posted on Jul 22, 2008
Black ink will not print but colors do
Most likely culprit is a dried up ink within the nozzles themselves. The best things for getting rid of dried ink in the nozzles is to use either a standard bathroom cleaner or rubbing alcohol. With the printer on open the door as if you were replacing ink. With the ink cartidges visable, unplug the printer so they stay put. Remove the cartridge and spray the cleaner in the where the ink is taking from the cartridge and clean it with whatever works. I really really good trick is if you have an old cartridge you can use a syringe to fill up the empty cartridge with your cleaning solution or rubbing alcohol. Insert the cartridge and run some test prints. This will for sure run the cleaner through the nozzle and hopefully dissolve the blockage.
Nov 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
Scanned document has a black verticle narrow line 3 1/4 " from the left edgle all the way down the page
Hi walt_latimer,
If when you copy or fax something and it has a black line running down the page, it is often caused by a dust, dirt spot or mark on the glass where it is being scanned. The easiest way to resolve this is by cleaning the feeder glass that reads it with a clean cloth.
Hope it helps.
Thank you for using FixYa.
Apr 30, 2011 | Epson Office Equipment & Supplies
Black line down page when in COPY mode on MFC-240C
You need to poiwer cycle after cleaning as the scanner only calibrates during power up. If all is clean, even the white bar over the small glass assembly, and you power cycle the machine and it's still there, you will need a new scan assembly.
Nov 24, 2009 | Brother Multi-Function Center MFC-240C...
Faint black line
clean the cartridge nozzle and check it.
Oct 09, 2009 | HP Office Equipment & Supplies
My black is really faded, when I print a test page by pushing photo and copy, however when I do a print head allignment the black for the allignment paper is sharp and deap, whats going on? Ive tried to...
The PHOTO mode is for printing grayscale photographs. Printed letters using PHOTO mode may appear faint because PHOTO mode is optimized for halftones. See if there is a TEXT or LETTER print mode, and try printing on that setting. If printed letters are still faint, you may have to go into ADVANCED PRINTER PREFERENCES, and see if the TONER SAVE mode is on. If it is, turn TONER SAVE off. Also, try changing the DPI image density, or try other adjustments in the ADVANCED PRINTER PREFERENCES MODE.
Aug 21, 2008 | Kodak Office Equipment & Supplies
Verticle line down left side of page
Printers tend to have this problem if for some reason dirt gets trapped under the print heads. A standard head cleaning is the best solution, which can be found in the menu.
Mar 18, 2008 | Lexmark X342n All-In-One Laser Printer
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
HP Color LaserJet 2600n Printer Logo
151 people viewed this question
Seeker5211
Seeker5211
Ben Johnson
