Question about Canon imageCLASS MF5750 All-In-One Laser Printer
Canon mf5750 will not pick up a fax it just answers then hangs up. doesnt make any different in any mod just will not pick up the faxs its makes the noise like its going to pick up but after about 10 sec it hangs up
  • kevinseward8 Mar 25, 2009
    wont receive a fax
How to get my fax to pick up.
Posted on Oct 24, 2008
I used to have a brother fax machine that received faxes when it detected a fax signal when my telephone's answering machine turned on. I tried all different settings with my Canon MX700 but it still won't...
Issue: Unable to receive faxes with an answering machine on the same line
Solution: Reduce the number of times the answering machine will ring before it answers the call (perhaps 3 rings max.)
An incoming fax may "hang up" if it takes too long for the machine to answer.
Dec 04, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I can't stop the fax from picking up all of my calls
there was a man/auto option under settings that was set to ON when it needed to be set to OFF. I changed it and now I can receive a fax manually when needed.
Sep 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
How to recieve messages on my answering machine and still recieve faxes
If your telephone service offers ditictive rng you can order another number and your line will ring differently and you can set you G3 Fax to answer the distinctive ring and you regular call will be picked up by the answering machine.
Sep 17, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Setting Fax to Respond to Fax Ring Signal on Dual Use Line
The Brother machine has setup for Distinctive ring, you pick the ring pattern that Embarq provides. The Brother instructions are in the operators manual. All Brother machines have this setup, not sure about others.
Aug 11, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Canon imageCLASS® MF4150 All-In-One picks up all calls on our second line.
I got in touch with the manufacturer tech support and found there was no way around it. Thanks for considering my issue though :)
Sep 12, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
FAX CONFIRMATION
You want to pay me I'll tell you how I fixed it,as you want me to pay for your service.I don't need your service I thought I was going to get a quick question answered.I didn't realize it was such a large matter.No thanks!
Aug 04, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Setting fax ringtone
get distinctive ring service from your phone company, that will get you a different number, on the same line, with different ringing pattern, my tel compnay charges $5 per month, then set the fax options to DRPD, and it will go directly to fax machine, while the phone calls on first number, will go to telepehone.....
Feb 13, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
MP730 fax issue-can't receive fax, but can send out
I think I know why. You need to set the proper priority of your all-in-one Canon device.
If it is TEL priority, it means you need to have a phone connected to the fax. If the phone rings, you need to pick up the handset and check if it's a fax tone or a call. If it is fax tone, you wait for 5 secs til fax tone stops, and then hang up. After that you will receive the fax. Failure to pick up the handset will not allow you to receive the fax. This might be the most probable setting you have, hence you can't receive the fax.
If it is FAX priority, the same thing happens as TEL priority. Only difference is if you don't pick up, and it is a fax, it will still receive.
You can also do FAX only. No need to connect a phone. Device will receive automatically.
-Acieboy
Sep 21, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Setting the voicmail
Voicemail or telephone answering device (TAD). There is a BIG difference. Voicemail is product of your telephone service provider. If you have voicemail, most providers have a solution to this that you must arrange through them. If you have an answering machine, you can set your Brother to TAD mode. In TAD mode, if your answering machine picks up, (you must set your answering machine to answer in less rings than your fax), your fax will "eavesdrop" to listen for the fax tones from the sending machine. If it hears these tones, it will disconnect your answering machine and accept the incoming fax. If it does not hear the tones, it allows the answering machine to record the incoming message. If you are home. If you answer the call and hear a tone every 2.5 to 3 seconds, that signals an incoming fax. Simply touch *51 on the keypad of the phone you picked up on. You will hear some shrill tones. That is your fax machine attempting to receive the incoming fax. Hang up the phone you are on and it will receive the fax. In any case, make sure that the receive mode is NOT set to AUTO. Set the receive mode to TAD or MANUAL. If these instructions were not clear enough, let me know and I will send you DETAILED instructions. You can find the manual here: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX2820_FAX2920_MFC7220_MFC7225N.pdf If you need additional assistance, please let me know before you rate this solution. Ed
Jun 29, 2007 | Brother IntelliFax-2820 Laser Fax
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
126 people viewed this question
old marine
old marine
