Question about Kitchen Ranges
De Dietrich double-oven; smaller oven on top; 1. fan won't switch off 2. oven won't switch on 3. light-bulb not working Larger bottom oven working fine, no evidence of blown fuse .!!!
  • 2 more comments
  • joanandkenmy Jul 22, 2008
    Repost
    Thanks ginko. I'll just hope for a 2nd opinion
  • joanandkenmy Jul 23, 2008
    Any other ideas? If not, I'm inclined to accept ginko's solution, but I've lost the e-mail to click on ACCEPT. Ken Myers
    First-time user of your service; I found it to be useful.
  • 640 Answers
Hi, I think your problem may be the door switch.Open the door and see if you can find a push button switch,on some of these models they have a magnet on the door.
Posted on Jul 23, 2008
  • 19,396 Answers
  • 3 more comments
  • Ginko
    Ginko Jul 22, 2008
    sorry wrong post, ask help from more experts if you want, I will see what I can find
  • Ginko
    Ginko Jul 22, 2008
    Unless is the oven control, they should be three separate problems. Easier to test is the bulb. If there is no power to the bulb but contacts, bulb are fine and there is no broken contact then there must be something wrong with the control.
    If control is fine then they are separate problems.
    Probably is just a control board to be replaced, you should call in a repairman and have it tested.
    If it is not the board would be a broken contact to the lamp, the fan blower, and something wrong with the oven not turning on.
  • Ginko
    Ginko Jul 23, 2008
    You can accept my solution here.
  • Ginko
    Ginko Jul 23, 2008
    One last hint, to get additional support you can check wo of our best experts has experience with similar models, and use the ask me button, here is the experts list.
  • Ginko
    Ginko Jul 23, 2008
    Many thanks.
I have a de Dietrich double electric oven with pyrolysis. I did a clean and now the bottom oven won't heat and fan not working. Top oven is fine, thank goodness
Many times when the self clean function is used they seem to melt connections internally . call your local repair company and have it checked out
Sep 24, 2016 | De Dietrich Ovens
Why did oven light explode
It may have been defective or the wrong type of bulb was installed. Only certain types of bulbs are rated for oven use.
Mar 21, 2015 | De Dietrich Ovens
Light on oven will not go off
oven door switch bad remove and replace it switch is located on oven not door
Oct 08, 2014 | De Dietrich Brandt Dedietrich Oven Grill...
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
N Serie: 04-09-01097 Ref DOD 348XXG11 Type E248H1 52106 The above are the details of my De Dietrich oven. My fan has stopped working and I need a new seal for the main oven door and for the...
We don't offer service engineers. Look in yellow pages or ask your oven supplier for a contact. Most Domestic Appliance companies can help you.
Sep 25, 2017 | De Dietrich Ovens
My de dietrich oven is not heating. the light and fan are ok
If the fan is working o/k, then the oven element is most likely faulty.
This is located at the rear of the oven compartment behind a removeable cover.
Feb 28, 2011 | De Dietrich Ovens
De Dietrich electric oven has power but no heat
hi it is probably the timer not making the switch properly even though it looks like its on stopping power going to the thermostat
Dec 11, 2009 | Ovens
Oven Light does not turn off
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Mar 08, 2008 | De Dietrich DOP390 Pyrolytic Electric...
My oven keeps turning itself off
the oven may be trying to protect itself because of a faulty device that says "I'm too hot". As electric clothes dryers have a thermal high temp limit switch to protect them, look for this device (may be 1 inch round with 2 wires connected) and replace it
May 24, 2007 | De Dietrich UMP404 Powerclean Stainless...
Kitchen Ranges Logo
113 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
