Question about Acer Aspire 3003LCi Notebook
How to change background
There are no tabs for desktop or screensaver under display properties. how do you change background?
    Genius:
  • 2,028 Answers
These tabs are the only way to change the background or screen saver. The display properties are integrated into the operating system, so, if the tabs are missing, this is an error with the operating system. Start with a system restore. Keep going back until they show on the display properties. If a restore doesn't work, then you will need to do an operating system repair with your recovery or operating system disc.
Posted on Jul 22, 2008
My screensaver will not come up on my computer
Depending on the operating system you have to go to the display setting to activate your screen saver. You can right click anywhere in the background and press on properties, the select screen saver on the tabs from top for windows XP or earlier. It's similar for win vista, 7 and 8 but its placed differently on the left side whe you select display properties.
Apr 14, 2013 | Computers & Internet
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
How to change the desktop background and screensaver
Hit the key with the Windows logo on keyboard as well as "M" key to minimize all windows that are open. Next, right click on background and scroll down and select "Properties". In the dialog that is now open you will see a tab labeled "Screen Saver" and another for "Desktop", these are used to change the screensaver and background, respectively.
Jul 10, 2011 | Computers & Internet
I want to change my desktop background. .what is the easiest and safest site to go to for reat pictures?
Right click your mouse on an empty area of the desktop. A small menu will appear.
  1. Click on Properties [This will be Personalize on Windows Vista or Windows 7] to open the Display Properties screen window.
  2. 3Select the Desktop tab, if using Windows XP. Windows 98 users can select the Background tab.
  3. 4Choose a background. On the lower left half of the Display Properties Window, you will see Background (Win XP) or Wallpaper (Win 98). You can choose a background from the long menu list by clicking on the background/wallpaper design you want.
  4. 5Select a position. Stretch is generally the best choice but if the image you have selected is of a low resolution or an aspect ratio different from your monitor's, then Center or Tile will work best.
  5. 6Click OK to close the Display Properties Window.
Feb 12, 2011 | Computers & Internet
Computer screen is distorted due to changing background, desktop and screensavers. how can I clean it up?
right click on the desktop => properties => settings tab then select the screen resolution. adjust it. find the proper screen resolution for your desktop
Apr 05, 2010 | Computers & Internet
How do I use my display setting, the desk and the screensaver?
right click on the desktop from mouse and then go to properties. now use the desktop tab to change the desktop settings like wallpaper and icons. and use screen saver tab to change or edit screen saver settings.
dont forget to vote
Oct 27, 2009 | Computers & Internet
How to set screensaver?
hi
first of all u need to right click on empty space on desktop and then select properties,once u have done that u will get a screen named display property ,,,,,,on the top u will find the tab screen saver.....click on to that and then select the desire screensaver and click apply and close ..........
Aug 31, 2009 | Computers & Internet
My pc M/s XP on startup is always in safe mode - I've tried msconf, etc but still cannot get any form of screensaver using control panel Display icon - any ideas
Hi
Restored Control Panel Display Desktop pic and Screensaver tabs by changing Registry items - Nodisplay background and Nodisplay screensavr to original setting (0) before virus / adware infiltration
regards Alex
Aug 23, 2008 | Computers & Internet
I cant get in to my screensaver settings, when i right click my desktop click on personalize then try to click on screensaver nothing happens and then everything sort of freezes i have a toshiba u405-s2820
This is only for XP and 2000. Also, try to change your desktop background before you use this information. The option to change the background is on the same screen as the screensaver settings. The tab says background instead of screensaver.
Download cleandesktop (http://thespykiller.co.uk/downloads/cleandesktop.exe)and save to your desktop. (right click save as)
Double-click on the cleandesktop.exe it will automatically extract to c:\desktopclean
Then it will automatically run the cleandesktop.vbs script.
It will then kill explorer. You will temporarily lose your taskbar and desktop .
It will then repair the registry entries returning your normal desktop and context menu functions.
It will then restart explorer. Your desktop will be shown again once you have performed the cleanup
Each of the other users on the system needs to be signed in to clean up their desktop and regain the right click.
Another vbs is included to do this. It is named "other profiles regfix.vbs".
Have each user sign in and run other profiles regfix.vbs.
Go to start > run and type: c:\desktopclean press enter double click on other profiles regfix.vbs
Explorer will be ended and that user's active desktop registry entries will be repaired.
Explorer will be restarted. To restore the desktop to whatever picture you normally have, right-click on a blank part of your desktop, select properties > desktop tab & select your preferred picture.
Press apply & then ok to exit and then press f5. (to refresh) you will need to do this step for every user account.
Thanks
Jul 24, 2008 | Computers & Internet
XP Pro Display Properties Desktop
check Display Properties, Screensaver tab, see if the "on resume, password protect" is checked. You've probably already checked on this, but...
Sep 12, 2007 | Computers & Internet
Acer Aspire 3003LCi Notebook Logo
129 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
