Question about Mitsubishi WS-55807 TV
Mitsubishi tries to come on
I have a mitsubishi ws55807. I can turn it on and I can hear the high voltage crackle and the tubes filaments are lit, but that is all I get. No sound or video. All the power supply voltages are ok. What could it be
  • 3 more comments
  • widgemix2003 Jul 30, 2008
    The power light stays on.
    What do you mean by increase the screens?
    How do you reset it?
    I am sorry. I am a computer technician. I used to work on TV's nad VCR's about 20 yrs ago. Ok, I turned up the screen and got a screen with some bowed lines on it. There was a fluid spill onto the signal board
    but I am not getting any video or audio signal through.Could the signal board be damaged?
  • widgemix2003 Jul 31, 2008
    cleaning didnt help. is there anyway to fix that board?
  • MICHAEL MULLINS May 11, 2010
    Good day, widgemix2003;
    All voltages are okay? Let me ask you a some questions, okay?
    1. What does the TV's power light do, blink or stay steady?
    2. What happens when you increase the screens?
    3. Did you try to reset the TV?
    Please let me know, big IRish.
Good Day, widgemix2003;
YES. The fluid may have damaged the traces on the boards. This isn't an easy fix. Look for the traces that are open are repair them. Scrape off the paint on traces, it will be easier to locate, also check the connector, between the two boards, for fluid.
Good Luck, big IRISH.
Posted on Jul 31, 2008
  • 927 Answers
I'm sorry, but when you said all voltages where correct, I assumed you was a tech or person with some TV knowledge.
Okay, let's start over:
1. To reset the TV unplug tha ac cord from the wall for 3-4 minutes.... plug back into wall.
2. On the front the TV behind the speaker grill there is a flat panel... remove.... you will a small black screen/focus block. On that item you will see the words screen , turn one of those slowy to the right. What do see on the TV's screen?
3. Since you have access to front look closely for fluid on the PCB. Look on the right and center of the board closely.
Good luck, big IRISH. Or call me on cell @ 281-380-4422.
Posted on Jul 30, 2008
  • MICHAEL MULLINS Jul 30, 2008
    The fluid must be cleaned off of the boards. The best Iv'e seen work is acetone. PAY attention to the on your left, that's were the vertical circuit is located. When cleaning LOOK for jumpers that may have corroded. Cover effective circuits with heavy plastic(like freezer bag) or 1/4 inch card board to protect PCB's from future leakage.
    The bowed lines indicate you have no vertical deflection.
    Hope this is helpful.
  • MICHAEL MULLINS Jul 31, 2008
    YES. The signal PCB may have fluid on it also (BRD on right). PCB could be damaged but attempt cleaning it first. The fluid may have damaged the traces on the boards. This isn't an easy fix.
How to check filament in tv
If it has a picture tube first look with set on, three tiny filaments will be lit if good, not real bright as 6.3 volts ac voltage across two pins on the actual tube.
If you can see them lit they are ok---most sets mark them on the board at the end of the neck for the picture tube with H for heater.
Very carefully as high voltages on the board measure for 6.3 volts AC across those pins. If for example its 3 volts that is too low and the voltage from those pins can be physically traced back to the High voltage transformer creates it off two pins.
less than 12 connections between source and the board on the tube, if missing voltage at the tube follow it back--a single cracked or bad solder connection can cause this.
Dec 22, 2012 | Televison & Video
No video only sound on CRT TV
possible no filament lit in the neck of the picture tube (there are 3 and not real bright as source is only 6.3 volts.
Possible no High voltage but most that have sound have high voltage.
You are going to have to remove rear cover to LOOK--be careful and let me know what you find, if no filaments are lit it will be a easy fix and should be easy to find---if no filaments let me know.
Dec 17, 2012 | Televison & Video
Good sound no picture
A older set------look to see if display comes on (channel number or menu) if not someone has to look to see if the filaments in the three picture tubes are lit or not.
Several voltages : High voltage, screen voltage, filament voltage all go to the picture tubes.
Oct 30, 2012 | Sony KP-61V75 61" Rear Projection...
Sonykv32s20 screen wont turn on, stays dark, but sound works
Its a older set, if you are able to open safely and run set JUST look to see if the faint filaments in the neck of the picture tube are lit, 6.3 volt filaments, and if they are not somewhere between source at High voltage transformer up to the PC board and socket at end of tube neck you have either a broken/bad solder connection or a open part--only about a dozen connections/parts between the two----set will have a ground and a voltage source at both ends of this chain, a bad solder connection will do this if filaments not lit(3 of them in neck of tube).
Oct 15, 2012 | Sony KV-32S20 32" TV
Toshiba 50A61 have sound but no picture - all fuses check okay
Not too many--if sound is developed from the set and not a surround system the set will blank the 3 picture tubes for a few reasons:
Voltages missing at the tubes (high voltage or screen voltages etc)
There is a loss of vertical sweep or horizontal sweep--set will do here this to prevent an INSTANT burn mark on all 3 tubes.
One thing you can try to look for is to see if the filament in each tube is lit---rather dim as 6.3 volt one---if lit the above reasons are your problem.
Without a meter, a schematic etc not much more you can check.
You should hear a faint whoosh sound when you power the set on--the high voltage coming up.
Jun 07, 2012 | Toshiba 50A61 50" Rear Projection...
Crackling noise on mitsubishi wd73833
I think it is safe to say that your lamp needs to be replace. The crackling that you here by the lamp is the Ballast striking, trying to turn the lamp on. It will try 3 or 4 times and then quit. Your Color Wheel is the other sound that you are hearing and is normal as well.
May 18, 2012 | Mitsubishi WD73833
CRT no image, sound ok. What could cause this?
WE can presume if static electricity on screen you have high voltage (most sets will not have sound if no high voltage).
If voltages appear to get good:
TAKE A CLOSE LOOK IN THE NECK OF THE PICTURE TUBE: all these sets the filaments in the tube should be lit when the set is on.
All are 6.3 volts AC (two filament pins on crt board--one is the ground and the other the AC--use that ground and carefully.
If no filaments or very very dim (they will be hard to see) the source for the voltage (if no or low filaments) comes from the high voltage transformer to the crt----usually one of two issues in this case---a part has opened or gone way up in value (resistor?)
It is a very simple circuit---just follow it back as usually on board that plugs to crt you will see something like H1 and H2. Follow both back and look for a broken connection or an open part between the tube and the source.
Let me know what you find and ask if more questions.
Mar 20, 2012 | Televison & Video
Mitsubishi ws55807
does the menu show up?
Oct 31, 2007 | Mitsubishi WS-55807 TV
Vs-5043 No Filaments lighting on any of the guns
Yes you have no High Voltage, and you have filaments if you look at CRT's and they are dimmly lit on neck of tube.:::::This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB
Jan 15, 2007 | Mitsubishi VS-5043 50" Rear Projection...
No picture
If, in a dark room you can't even see the screen lit up, you have probably lost your high voltage driving the picture tubes and if the set is over 10 years old, I'm pretty certain that the parts will be no longer available -- that is one of my pet peeves about Mitsubishi. If you can see a grayish screen, then maybe there's a chance it could be repaired by a competent and dedicated technican.
Jan 13, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi WS-55807 TV Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
